Hi all
I've a 55 plate 1.6 16v dymanique. The reverse switch which enables the reverse lights and wipers appears to be knackered and I'm wondering how much the cost would be for replacement at a main dealer. I'm based in Newcastle upon Tyne If that helps.
Cheers.
Reverse Switch
Re: Reverse Switch
Why go to main dealers they are only about £15 from a motor factors
Try Andrew page or Brown brother just behind brough park on the fossway walker/byker
Steve
Steve
- Currently Drives:: Renualt megane 1.5cdi (80 dyo) blue
Re: Reverse Switch
Try renualt on the felling bypass
Glad to here someone else is near is
Re: Reverse Switch
Cheers for the replies. Has anyone got any idea of the cost to fit the part with a main dealer?
Re: Reverse Switch
jack car up take off near side wheel and arch liner
look at side/end of gear box
green plug
take off the lead
use spanner to remove but be ready to cover hole with finger for the oil coming out
swap in new one and tighten
Steve
green plug
take off the lead
Steve
Users browsing this forum: No registered users and 80 guests
