Can't remove rear wheel..
UK.BladeRunner
Currently Drives:: Renault Megane 1.6i Dynamique VVT 3Dr Sport (57 Reg)
Postby UK.BladeRunner » Mon Dec 13, 2010 12:40 pm
Have got a flat tyre at the moment on my MkII Megane Dynamique and have removed all of the wheel locking nuts (x4) on the rear passenger side wheel
Wheel is about 1/2 an inch off the ground with the car being raised via it's jack...
Doing everything i can to get the wheel off but it's not budging!!! Serious head scratching here...!! :hm
Any suggestions please?
Many Thanks
UKB
Renault Megane 1.6 VVT Dynamique Sport Hatch. | 57 Reg |3 Dr | Manual Gearbox | Panoramic Elec Sunroof | Cruise Control | Speed Limiter | Air Con | Elec Windows | Elec Mirrors | 6 Disc CD Changer | Front Fog Lights | Keyless Entry & Start
funkyg
Currently Drives:: Megane III dCi 106
Re: Can't remove rear wheel..
Postby funkyg » Mon Dec 13, 2010 3:58 pm
Tap it with a rubber mallet.
Postby joeishmather » Mon Dec 13, 2010 4:54 pm
My fiancaees sister had this problem on her golf, we pit the car back down with all the bolts still out, rolld forwards a foot or two n pulled on the handbrake, the wheel still moves as tho the car was rolling n the hub stays still, then jack the car back up n it's off easy peasy! ;-)
let me know how u get on...
UK.BladeRunner
Postby UK.BladeRunner » Mon Dec 13, 2010 6:01 pm
joeishmather wrote:My fiancaees sister had this problem on her golf, we pit the car back down with all the bolts still out, rolld forwards a foot or two n pulled on the handbrake, the wheel still moves as tho the car was rolling n the hub stays still, then jack the car back up n it's off easy peasy! ;-)
Sounds like a plan that... Will give it a go tomorrow morning first thing!! :rock
Have tried the tapping with a rubber mallet etc.. Even had my entire weight behind pulling the darn thing off but it just won't budge!! :banghead I believe because the car is only just over 3 years old the wheels have never been removed before (original tyres) and thus may have rusted a bit to the Arm hub!!
Cheers, and will let you know how i get on!!
rjacko
Currently Drives:: Renault Megane 1.9 dci Dynamique, 3dr 03 reg
Postby rjacko » Mon Dec 13, 2010 9:37 pm
Put some copper grease on back of wheel when you put it back on. Stops the wheel sticking to the hub.
Postby joeishmather » Mon Dec 13, 2010 10:00 pm
rjacko wrote:Put some copper grease on back of wheel when you put it back on. Stops the wheel sticking to the hub.
Some good advice there n even if it's another 3 years it should come off easy! :-) n good luck for tomorro!
davet47
Currently Drives:: 06 Megane CC 1.9dCi
Postby davet47 » Tue Dec 14, 2010 8:55 am
I can see this being a disaster! Leave the bolts in but loose otherwise there's a possibility of the wheel coming off and the car dropping to the ground.
I would spray some WD40 on the centre of the wheel and then, with the car securely supported, whack the rim from the back with a weighty copper/hide mallet while turning it-"tapping" will not do the job.Copper grease advice is excellent-might as well do the whole lot while your are at it.
Postby joeishmather » Tue Dec 14, 2010 9:38 am
I took the bolts out as didn't want to end up damaging them or the wheel, if the caronly moves in a straght line and tge ground is even there shouldn't be any problem.. There's no force pushing the wheel sideways, anyway I think with one rear wheel off on a megane you can take the jack down as the front end keeps the back quarter without the wheel up..
UK.BladeRunner
Postby UK.BladeRunner » Tue Dec 14, 2010 4:20 pm
Yep, all done guys... Just rolled the car very slightly (in a straight line) ;) , hit the hand break and that slight force was all that was needed to free the wheel from the hub. Jacked it up and it came away easy.... :rock
Thanks Joe
Postby joeishmather » Tue Dec 14, 2010 5:53 pm
No problem quite a handy trick in my experience!
Glad I could help!
Users browsing this forum: Bing [Bot], Google [Bot] and 46 guests
