Rear brake lights not working
camel
Postby camel » Mon Sep 10, 2007 8:59 pm
Hi, noticed the rear nearside brake light was not working and presumed bulb had blown. However when i went for a new one, the offside light was not working either. Had bulbs checked in motor shop and working fine. Connectors seem ok and presume fuse is ok as eye-level central brake light working ok. Anyone had a similar problem or any idea what to try next? Car is 54 reg and 36000 service due next month - warranty expires in Nov!! Thanks
1.9DCi, 3 door, flame red, 17" alloys, full leather, heated seats, panoramic s/r, climate control,multi cd
renier
Postby renier » Mon Sep 10, 2007 9:20 pm
If you still have warranty, why not go back to the dealers and let them sort it out? :D
camel
Postby camel » Mon Sep 10, 2007 10:15 pm
Hoping for a quick fix, can't afford to be without a car at the moment and dealer usually needs it all day whatever the problem!!
cactusbob
Postby cactusbob » Tue Sep 11, 2007 8:01 am
I would check the fuse anyway
225 5dr FF + Xenons
http://www.meganesport.net
Mike_M
Re: Rear brake lights not working
Postby Mike_M » Mon Aug 31, 2009 6:08 pm
any more news on what had happened, mine's done the same. :(
gav1pam
Postby gav1pam » Mon Aug 31, 2009 7:26 pm
im an auto electricion on commercial vehicals,
on some the brake lights either side or on different looms and sometimes different fuses.
Obviously so both lights dont stop working at the same time.
Im not sure if this is the case on the meg.
Deffo check the fuse first though
swede
Currently Drives:: Renault Megane 1.6 dynamique
Postby swede » Thu Dec 02, 2010 7:06 pm
Had the same problem with my 54 megane today. Off side brake light not working so changed bulb but still no joy. Fuse is not problem as only 1 fuse for both sides and break light above rear window and near side and other working fine.
Swede :banghead
acidburns82
Currently Drives:: Renault Megane Sport 225 cup
Postby acidburns82 » Mon Jun 13, 2011 2:05 pm
swede wrote:Had the same problem with my 54 megane today. Off side brake light not working so changed bulb but still no joy. Fuse is not problem as only 1 fuse for both sides and break light above rear window and near side and other working fine.
Swede :banghead
I have got a megane sport 05 and i have got the exact problem you have, have you found what the problem is yet?
barry.croston
Postby barry.croston » Sun Apr 15, 2012 1:54 pm
Anyone get this problem fixed ?
Postby davelowe » Sun Apr 15, 2012 9:49 pm
The wiring in these models would challenge God.
You could have an earth problem; a bulb holder problem; ad infinitum.
Also, on some models, the wires are different colours on opposite sides of the car.
I would meter the various endings when the pedal is pushed. The more common problem is the top light - whereby the cause is usually a problem in the loom through the boot lid.
Check for all the obvious, then report back. I've never come across a problem of this sort that can't be cured for pennies, although I can always be proven wrong!
barry.croston
Postby barry.croston » Mon Apr 16, 2012 1:35 pm
Where is the earth for the rear lights usually. Both wires are same colours black and white on n/s and two black one white o/s
Postby AlexB » Mon Apr 16, 2012 4:56 pm
The wiring diagrams are in the sticky thread...
barry.croston
Postby barry.croston » Mon Apr 16, 2012 5:59 pm
Cheers will look now
Postby davelowe » Mon Apr 16, 2012 9:42 pm
Remove the carpet and rearmost trim from the boot. The earths are as clear as daylight (bolted direct to the chassis). Can't miss them.
barry.croston
Postby barry.croston » Mon Apr 16, 2012 10:56 pm
Cheers will test them tomorrow.
Users browsing this forum: Google Adsense [Bot] and 31 guests
