Main/Full Headlight Beam
np666
Currently Drives:: Renault Megane DCi 2004
Postby np666 » Tue Nov 23, 2010 12:52 pm
Have read a load of headlight related issues on here and am still confused. :conf
Only got my Meg 3 weeks ago but have noticed that when the headlights are on everything is fine (alignment/brightness etc) however when I switch on the main/full beam I only illuminate the same area that the headlights are in. So I guess that the main beam bulbs need to be adjusted, which is where the confusion arrives, I have read on here that the main and dipped lights are adjusted together so what can I do?
Also I read that it is a bit of a nightmare to change the bulbs, can someone tell me or proivde a link to instructions how the best way to get access and change them? It seems bizarre that in a country where it is a legal requirement to carry a spare bulb in the car the French would make it a little easier :nut
I have the auto lights which are great and I want to keep on )i know you can de-activate them), but when they are on how do I dip them to side lights when the stalk and switches are in the off position? (need to do this when I enter my place of work so I don't blind the security gaurd)
Would appreciate any advice or solutions thanks fellas (or ladies, dont want to offend anyone :grin )
I was worried about buying a Renault, now I have bought it I am waiting for it to go wrong............but I like it!
Gav
Re: Main/Full Headlight Beam
Postby Gav » Tue Nov 23, 2010 1:03 pm
np666 wrote:when they are on how do I dip them to side lights when the stalk and switches are in the off position? (need to do this when I enter my place of work so I don't blind the security gaurd)
You need to twist the stalk to side lights to get side lights. The auto setting is only for dipped beam.
np666
Postby np666 » Tue Nov 23, 2010 1:05 pm
OK, ok sorry I'm and idiot. :oops:
Found some advice on here for headlight adjust : viewtopic.php?f=10&t=6307
np666
Postby np666 » Sat Nov 27, 2010 5:08 pm
Someone help/advise!!
Had a bit of a nose around and even fitted new bulbs for the full beam but makes no difference!! :banghead
The bulbs are defiantly fitted correctly but the full beam is still too low, I live in the countryside and driving down an road that has no street lights at 60mph and having only the 50-100ft in front of you lit up is a little disconcerting.
The dipped beam I am sure is correct, and even if they were a little low the main beam should still be illuminating the area 'above' the dipped beam shouldn't it?
madwedge
Currently Drives:: 2004 Renault Megane 2.0 litre 16v VVT Dynamique
Postby madwedge » Sat Nov 27, 2010 5:41 pm
Make sure the headlight adjustment control is on the right setting (i.e. not on the setting as if you had a fully loaded car). It's located on the lower right hand side next to the steering wheel. Next to the dashboard light intensity control.
np666
Postby np666 » Sat Nov 27, 2010 5:53 pm
yes, have checked that. It is set to zero.
Users browsing this forum: Google [Bot] and 68 guests
