Blower
Funnily enough I have just returned from a Renault dealer and I asked about this problem (my Brothers Scenic had the same problem - which now seems to have cured itself).
It is a problem with the heater resistor and needs replacement - Something covered under Renault warranty I believe.
Hope this helps.
Hope this helps.
Re: Blower
Bump!
My blower now only works on 1, 2, 3 settings - it stops on 4.
Any ideas where I start to repair this?
5dr 1.6VVT Hatch, Pearl Black Megane Dynamique + Comfort Pack, '53 plate
Re: Blower
strange as problems normally occur the other way around.
on setting 1,2 and 3 it goes through the resistor (behind panel under glove box)
on setting 4 is goes direct to blower.
the usual problem is it works on 4 but not the others and this would be a resistor issue.
you might need to check the wiring with a multimeter etc.
Re: Blower
Sorry to open an old thread but did you ever find the problem with this as I have the exact same thing.
Works on 1,2 and 3 but not on 4
Re: Blower
karllap wrote:Sorry to open an old thread but did you ever find the problem with this as I have the exact same thing.
Sadly, still waiting some help...
- dean-weston
- Currently Drives:: 54 Megane 2 - 1.6VVT
Re: Blower
Hi, iv just had the exact same problem..... firstly the blower was intermitant on pos.4 fine on 1.2.3.
Last week it went completly on 4. So after reading up a little I removed the pannel in the passenger footwell that lets you access the center console, and (as im a cowboy) i hit the connector block a few times which is located at the back and appears to have a thick red and yellow wire going into a block with several other wires on the other side. best do this with the ignition off.... Now once i started it up the blower was working fine, however..... a plasticy burning smell was present after a while on pos.4
SO... some more reading up told me this is ANOTHER common fault, where that the resistor connector block (i think) has a bad connection and causes it to become hot = burning smell / stops working. my next job is to read up a little more and find how to solve this properly. Im led to believe changing the connector block or bypassing it all together is the way forward, but as im no auto-electrician im going to be steady in my approach....
If anyone has any more info please let us know.......
Re: Blower
Progress on this at last - please keep us posted...
(I might try the same actions as you!!)
- dean-weston
Re: Blower
UPDATE:
Pos 4 has now totally stopped working, due to the cold weather i had the car running, heater on P4 after 5 mins a burning smell and smoke - im going to attempt a fix at weekend, i'll include pics and a walkthrough if it works....
FYI - found this > https://www.renaultforums.co.uk/showthre ... t=resistor
- Currently Drives:: Renault Megane II 1.9 dci (2004)
Renault Megane I 1.6i 16v (2001)
Re: Blower
Morning guys, sorry I know this is an old post, but having just got my Megane 3 days ago I found that settings 1,2 and 4 do not work on my blower, only setting 3 - any ideas?
Re: Blower
£165 inc VAT/fitting (give-or-take) for a new heater motor resistor and wiring loom (mine had burnt out)- it's what mine needed.
- dean-weston
Re: Blower
__spc__ wrote:£165 inc VAT/fitting (give-or-take) for a new heater motor resistor and wiring loom (mine had burnt out)- it's what mine needed.
bloody hell, im glad i got mine sorted before the wires melted, i could see smoke and smell burning a few times, but luckily i caught it before it was too late, and all it cost was the price of some cable, a few strip connectors and some electrical tape
