Postby tomalamix » Wed Sep 01, 2010 5:22 pm
If the car revs up and starts it shouldn't be necessary, at least from my experience i never saw one that needed programming as far as the car starts up and revs up. Yours are doing both so the problem shouldnt be on the injectors program. EGR is clean...and you have a rough idle and too slow reving up with no warning coming on the dash. The turbo youve said is fine, but lets no go that way because the turbo doesnt make a rough idle. Timing belt is my best guess...its correctly installed, everything were on the right spot (close is not good enough, must be on the spot)? If not the problems you should have is exactly the same you're saying, smoke, rough idle and slow reving up. Check that, the head were off and its a strong possibility...
Good luck
