Keyless Entry Query
simon72
Currently Drives:: Vauxhall Omega 2.2dti 16v
Renault Megane 1.6 Privilege Hatchback 5dr
Keyless Entry Query
Postby simon72 » Fri Jul 30, 2010 10:44 pm
Hello all and what a great forum.
i have tried to find the answer to my next question but have failed.. So here goes (And sorry if it has been asked before)
Right my wife and I have picked up her Megane today and have already stumbled on a problem
(03 reg 1.6i 16v vvt, 5dr, PRIVILEGE, Quite a few toys on board)
Right Keyless entry problem.
Right I can lock and unlock the car using remote buttons.
I can start car with key card in my pocket
I can lock car with all external button (4 on handle, 1 on boot)
I can then walk up to car and unlock the boot without using remote by just getting close to boot and using boot release..
BUT heres the problem... I CAN NOT open any of the door by just grabbing a handle and pulling even when close to the car I have to then use the remote to unlock.
What am I doing wrong or has the function been disabled in any way???
Help appreciated.
Simon
BlueMeganeII
Currently Drives:: 03 Megane 3 door 2.0 VVT Dynamique - Sunroof, 17" Alloys, Keyless Entry and start
55 Grand Espace Initial, Xenons, Leather, Sunroof, Keyless, Sat Nav, Tyre Pressure sensors, 18" Alloys, Roof spoiler/bars.
Re: Keyless Entry Query
Postby BlueMeganeII » Sat Jul 31, 2010 9:42 am
The door handle sensors have probably failed. Its really common.
Ray
Postby Ray » Sat Jul 31, 2010 1:46 pm
what he said... quite an expensive fix too
simon72
Postby simon72 » Sat Jul 31, 2010 5:05 pm
All of them together?
Is there a way of testing them or even getting to them to remove and look at?
BlueMeganeII
Postby BlueMeganeII » Sat Jul 31, 2010 6:15 pm
Yep all of them likely died one after another before you got it. My first Megane had all but one fail, didn't get it on my Scenic for that reason and my current Megane hasn'r had any fail at all - yet... If you got it from the dealer hold them respsonsible if they advertised the feature to you, if not get ready for a big bill unless your able to do the job yourself.
simon72
Postby simon72 » Sat Jul 31, 2010 6:50 pm
Yes I would be able to do the job myself, any idea on price for the sensors, or even a part number?
Postby Paddy » Sat Jul 31, 2010 9:26 pm
simon72 wrote:Yes I would be able to do the job myself, any idea on price for the sensors, or even a part number?
Expensive very expensive as new.
Best bet is to get along to a breaker and strip them out.
BlueMeganeII
Postby BlueMeganeII » Sun Aug 01, 2010 5:15 pm
No actually the sensor is really cheap £25-£35. I think the handle was £70. Once you've opened up the door handle you may be able to save some of the sensors once you have dried them and check for corrosion etc.
simon72
Postby simon72 » Sun Aug 01, 2010 5:22 pm
BlueMeganeII wrote:No actually the sensor is really cheap £25-£35. I think the handle was £70. Once you've opened up the door handle you may be able to save some of the sensors once you have dried them and check for corrosion etc.
Is the sensor in the Door Handle itself
OR
is it the black square pad with the two circles on the door panel??
Cheers for the help
BlueMeganeII
Postby BlueMeganeII » Mon Aug 02, 2010 7:20 pm
You have two parts, one behind the black square part is the cheaper part which suffers from water ingress. The other part the handle can fail aswell so doesn't unlock when you pull the handle or lock when you press the handle.
simon72
Postby simon72 » Mon Aug 02, 2010 8:15 pm
BlueMeganeII wrote:You have two parts, one behind the black square part is the cheaper part which suffers from water ingress. The other part the handle can fail aswell so doesn't unlock when you pull the handle or lock when you press the handle.
Cheers, I will strip all door and get the sensors out and see if I can dry them out and get them working again.
