Meggy 2 ph1 1.9dci 120ks - Diagnostic Codes - please help
sp00ky
Currently Drives:: Renault Megane 1.9dci
Postby sp00ky » Thu Feb 18, 2010 6:21 pm
i just scanned my Meggy 1.9Dci 120hp 2005 with ELM327 1.3a and found this errors:
P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
P0772 Shift Solenoid "E" Stuck On
B1612 Wiper Rear Mode Select Switch Circuit Open (probably because is wipers are worked)
Could someone with experience can explain what they means ???
Re: Meggy 2 ph1 1.9dci 120ks - Diagnostic Codes - please help
Postby AlexB » Thu Feb 18, 2010 8:37 pm
The first is the boost control solenoid malfunction. There exist other codes for the control being stuck in high or low. Check the solenoid, vacuum pipes/receiver, the turbo actuator, connectors and the valve itself.
The second is the auto gearbox loosing half of its gears. There is not much you can do with it. The dealer can try to release the corresponding clutch by sending command from the Clip computer. ...unless it was an intermittent fault that cured itself.
Before you asked - the repair manual is in our Links.
sp00ky
Postby sp00ky » Thu Feb 18, 2010 9:17 pm
AlexB wrote:The second is the auto gearbox loosing half of its gears. There is not much you can do with it. The dealer can try to release the corresponding clutch by sending command from the Clip computer. ...unless it was an intermittent fault that cured itself.
huh... i have 6-gear manual transmission !?
Postby davelowe » Thu Feb 18, 2010 11:19 pm
sp00ky wrote:huh... i have 6-gear manual transmission !?
For f***s sake!
Does the car drive 'normally'?
Clear the codes, drive for a few miles and recheck. They maybe just stored in memory from time immemorial.
Users browsing this forum: No registered users and 73 guests
