hey guys. Got a 54 plate megane 1.9 dCi. Was driving around town 2day and everytime i used the clutch, the pedal was making a clicking sound, then suddenly it stuck 2 the floor for about a second or two then came back up and now the pedal doesnt come up as high as it used 2 and also the clutch is now slipping slightly. It was absolutely fine before this happend. The car has done 73000 miles. Any ideas?
Cheers...
Clutch problem
- Currently Drives:: 54 plate Renault Megane Dynamique 1.9 dCi (120) Black, 3 Door
Clutch problem
black, 3 door, 54 plate megane 1.9 dCi 120 dynamique, GET RID OF IT!!!! IT HAS R@PED MY BANK ACCOUNT!!! NOTHING BUT F**KING TROUBLE!!!
Re: Clutch problem
1. Clutch pedal mounting defect (never heard of that before)
2. Air in hydraulic clutch pipes / leaking pipework (possible)
3. Fluid level low (check it - might have lead to/caused by 2)
4. Master or slave cylinder failure (been reported before)
5. Clutch friction plate worn out (possible if it's the original)
The clutch is self adjusting in travel. Personally I haven't heard of them failing suddenly, but if it will not adjust further because its worn, then that might be the problem. 100k is typical, but stop start driving might shorten the life.
I await correction.
I await correction.
Re: Clutch problem
ive taken it to a couple of garages and all of them say they will have to strip the car down to find the problem. Most of them are saying its the clutch and Dual Mass Flywheel
Ive had clutches go on me before, and this does not feel like a worn clutch
Re: Clutch problem
took it 2 renault and they said its the Master Cylinder. Any idea where the best place is 2 get it from? Do i have 2 get it from renault? And any idea on price?
Re: Clutch problem
ended up being the clutch pedal return spring! Renault said there was no spring! WRONG!!!
Re: Clutch problem
Result - a rare moment of sense from a garage!
