Stuttering starting
DriverDeluxe
Stuttering starting
Postby DriverDeluxe » Thu Apr 16, 2009 2:06 pm
I have the 1.6 vvt dynamique.
Anyways i've had the TDC sensore changed and it drives like a dream.
One thing i have noticed since i have had it is..
When i press start the engine seems to start then pause and then carry on starting. It does this every so often and i am worried it will lead to something bigger.
Any ideas what is causing this?
AliasOmega
Currently Drives:: 1.6 VVT
Re: Stuttering starting
Postby AliasOmega » Sun Apr 19, 2009 10:47 am
Mine did this a few weeks back, i ignored it and its been ok since.
If your looking for a problem, then you will find one.
Postby AlexB » Sun Apr 19, 2009 11:28 am
Does it disengage the starter in between or just having a difficulty in completing the first cranking turn? In the latter case it can be a weak battery.
Paul79
Postby Paul79 » Sun Apr 19, 2009 8:09 pm
It does it rarely and it has had a brand new battery fitted.
I press the button, it pauses then carries on firing up. It gets there. Once i started it and it kept on making the cranking sound over and over again and i had to press stop and do it again. It seemed to get stuck?
I've been told it's a problem related to the alarm, imobiliser. Because when this starts happenign the alarm will keep going off. Then it will be ok for a few days.
Does this sound possible?
Postby AlexB » Sun Apr 19, 2009 10:17 pm
Please wait a moment... I don't understand two things. Are DriverDeluxe and Paul79 the same person? The second thing -- are you saying that the starter motor stays engaged or repeatedly engages when the engine is already running? It sounds like a problem with the starter.
Paul79
Postby Paul79 » Mon Apr 20, 2009 9:52 am
Sorry DD is using my works Computer.
Is a starter motor expensive to fix?
