Changing the Sidelight Bulb...
WildgooseUK
Currently Drives:: 2003 Renault Megane 1.9DCI Dynamique
Postby WildgooseUK » Sat Feb 21, 2009 4:22 pm
Hello All,
I'm really stuck here as my Sidelight bulb has blown. Anyway, does anyone here know the best way to change the bulb without shredding my arms. it's on the nearside, and I have changed the headlight bulbs before with no problems by accessing it under the wheelarch, but the sidelight is a different matter.
Does the Sidelight pull out or do you need to turn it for it's removal?
Any recommendations will be very much appreciated.
steve the postman
Currently Drives:: 1.5 DCI 86 EXTREME TUNING BOX
DAB DIGITAL RADIO/DVD PLAYER
HID HEADLIGHTS
PIAA HORNS
GT LEATHER STEERING WHEEL
Re: Changing the Sidelight Bulb...
Postby steve the postman » Sat Feb 21, 2009 4:27 pm
Small squeeze clip on bulb holder
then slide backwards to remove
Steve
WildgooseUK
Postby WildgooseUK » Sat Feb 21, 2009 4:38 pm
Thanks for quick reply Steve.
Are you referring to clip that holds the headlight bulb? And, have you done this before as I've open the bonnet and took the plastic cover off so I can see from above and the cover under the wheel arch. What is the best method to replace the side light bulb anyway?
steve the postman
HID HEADLIGHTS
PIAA HORNS
Postby steve the postman » Sat Feb 21, 2009 5:09 pm
phase 1 the bulb is below the dipped beam
phase 2 the bulb is in with the main beam
the clip is on the black bulb holder
it is easier to jack up car and remove the wheel
even better to remove the arch liner by three big push in bolt things much better access
cap off squeeze the clip slide out holder bulb pushes into that
Steve
WildgooseUK
Postby WildgooseUK » Sat Feb 21, 2009 5:43 pm
Thanks again. Will have another go in the morning as it's getting dark now. Will attempt to remove wheel arch cover but leave wheel on as my driveway is sloped downwards, so I can't really use the jack.
Will let you know if I succeeded :?
steve the postman
HID HEADLIGHTS
PIAA HORNS
Postby steve the postman » Sun Feb 22, 2009 9:20 am
Jack up enough to raise the car but leaving wheel on ground
Will give more space to work
Steve
Meggyman
Currently Drives:: 56 Megane CC 2.0 Privilege in grey.
Full leather etc
Postby Meggyman » Mon Feb 23, 2009 12:52 pm
Well apparently, if you strip every part of the car away from the headlamp unit you'll be able to get at it. :D
Sorry to make light of a bl**dy annoying problem, but when you consider its a legal requirement in France to carry spare bulbs, it seems that a French car designed to be almost impossible to change Headlight bulbs etc was a slight overthought.
Perhaps Renault will supply a blow up technician to keep in the boot to change em for you!
Errrr............ You can guess where the inflation valve would be placed if you let a Frenchman design it!
See 'Airplane' for a reminder :shock:
56 Megane CC 2.0 Privilege in Grey.
Full leather etc
WildgooseUK
Postby WildgooseUK » Tue Feb 24, 2009 11:25 am
Well....the good news,I succeeded replacing the Side light Bulbs. But it was NOT easy, specially the nearside.
The bad news, I lost one plastic clip that holds the bulb holder in place. Is there anywhere I can get a replacement or otherwise, I just use blu-tack. :-(
Users browsing this forum: No registered users and 67 guests
