I'm not paricularly mechanically minded but I thought even I could change the brake lights on my Megane (1.6, 53 reg). However I was wrong or is it me....
Both back brake lights are not working although the one across the top of the boot still is. After a bad experience with the headlights from a Renault dealership last year I refuse to take it back to them (afterall how hard can it be to change a brake light!!!!)
Well I went to Halfords picked up some new bulbs, took apart the back lights to do a simple swop and hey presto, nothing!!
I've even taken the reverse light out as it looks a similar type bulb and placed that into the brake light and it still does not work.
Is it the lights I've bought (they look the same) or could it be the electricals?
Any help would be much appreciated
brake lights
Re: brake lights
hello i have same problem did you manage to fix this and find out the cause?
Re: brake lights
What about checking the fuses fellas? All info found in handbook!
Re: brake lights
all checked plus the hi-level central brake light works fine which is on the same fuse.
Re: brake lights
this is exactly why i visited the forum today, my brake lights haev done exactly the same thing...
The high level light works fine but both low level cluster brake lights have stopped working. I've pulled the fuse and checked that, that buzzes fine, i've pulled both brake bulbs and they buzz fine too. Got my other half to step on the brake pedal while i multimetered the contacts, zero. I did this again on the RIGHT side cluster directly on the connector itself and got 0.2v when pedal pressed.
Any idea on whats happened???
Mike.
Mike.
Re: brake lights
i know this is an old post,
but did anyone find a fix for this... one of my brake lights has decided to stop working today, changed the bulb but still no luck.
any ideas?
thanks dom
any ideas?
thanks dom
Keen If Nowt Else
Re: brake lights
hy
maybe the brake switch on the pedal. does the car turns on when you press the brake pedal instead of the clutch?
- Currently Drives:: megane ii sports hatch 1.9 dci dynamic 130
Re: brake lights
I had the same problem with my 2006 Megane. I sprayed the connector with electrical contact spray and the light worked for 2 weeks. I took it to twotechs renault specialists and Matt adjusted the female connectors, but the brake light went out again after 2 weeks. Before the MOT I cleaned the male connectors with a small file and spayed them with electrical contact spray from Maplin and the brake lights been working OK ever since
Lee
Lee
Re: brake lights
carefully stick a needle on the brake light harness and measure there if there is 12v or not. That 0.2v doesnt even count
good luck
good luck
