How to remove drivers airbag?
Mike_M
Re: How to remove drivers airbag?
Postby Mike_M » Mon May 12, 2008 6:06 pm
nope the number on the big white sticker in the black folder doesnt work. Washington Renault in Sussex LOST my service book which prob has the code in it, so i'll expect them to supply a replacement code for free, will go bang some desks in the morning :twisted:
gingeralls53
Currently Drives:: megane1.4 16v
Postby gingeralls53 » Tue Jul 08, 2008 4:36 pm
hi i have a 1.4 2003 expression and need a clockspring can anyone tell me the part number or how to find it thanks..
paulmcglennon
Currently Drives:: Megane
Postby paulmcglennon » Sat Feb 21, 2009 3:34 pm
Ok guys, helping out a friend here and saving her a few quid on renault labour costs, struggling with the air bag removal! its doesnt want to budge!!! help me
Paul
steve the postman
Currently Drives:: 1.5 DCI 86 EXTREME TUNING BOX
DAB DIGITAL RADIO/DVD PLAYER
HID HEADLIGHTS
PIAA HORNS
GT LEATHER STEERING WHEEL
Postby steve the postman » Sat Feb 21, 2009 4:24 pm
Disconnect battery go have cuppa for 30 min
remove steering column covers 3 screws underneath
feel back of steering wheel to locate hole
use an 8mm drill bit blunt end push gently into hole
gently pull the air bag forward then up to slide off towards screen.
undo 2 conections air bag is off DO NOT DROP it can still go off
I WILL NOT be responsable for any injuries sustained
Steve
tony2311
Postby tony2311 » Wed Jun 17, 2009 1:28 pm
just add acouple of bits. when pushing the drill bit in, It needs a bit of force as to move the airbag out of the clip then the air bag should come slidle off quiet easy upwards.
when disconnection the airbag the wiring should be disconnect from the airbag side. there is a clip on each side you have to lift with small screwdriver before the plug will come out(both colour coded so it wouldnt be wrong.
if you are replacing a like for like wheel from renault there is a center line already on the spine and wheel so you just line it up ,
i replace my plastic worn 60000miles steering wheel with this
https://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0430904939
£24 what a bargin and it was brand new
Users browsing this forum: Majestic-12 [Bot] and 61 guests
