Electric windows
newts40
Currently Drives:: 2005 5 door Megane Privilege 1.6 Petrol
Electric windows
Postby newts40 » Mon Jun 30, 2008 11:32 am
I'm a new (2nd) owner of a 54 reg Megane Privilege with about 50K miles.
However i've only done about 200 miles in 3 months and now the drivers side electric window will not go down. The other 3 work
Is this a common fault and a possible loose wire that can be quickly fixed, or something more sinister.
I knew i was in for some unreliable French moments but this is ridiculous!!
PLEASE HELP!!
nickbell69
Re: Electric windows
Postby nickbell69 » Mon Jun 30, 2008 7:27 pm
Very common problem on Meganes. Do a search and you will find loads of posts on this. There are also posts of people getting it repaired free through Renault out of the 3years warranty as its such a common problem. Could be a number of things usually caused by water getting into the door!! 1st off though have you tried the reset? Holding all the window buttons up for 10seconds(not sure if ignition should be on or off, try both) resets them. Try that before you take it in.
Users browsing this forum: Bing [Bot] and 41 guests
