My company has just bought three clio campus vans and all of them to some extent have what can only be described as a shudder.
the van starts fine but one of them can shudder in first , second ....fifth gear at various speeds. It is almost as if you are driving along riding the clutch and then pulling it back and you get the jolt. However there is no change in revs etc like you would expect if you do this.
The other two vans do it to a lesser extent but still do it.
Any ideas what could be causing this.
the stealer has done extensive tests and found nothing.
When asked if they road tested it they said yes and with a computer. - probably put it on a rolling road
