Door card removal
villi
Door card removal
Postby villi » Tue May 06, 2008 9:00 am
Ok, so i think my passenger window regulator is nackered. It has been acting strangely, it got stuck open then it would open itself when deadlocking and now it just wont work, but its shut so thats ok.
I am trying to get the door card off to get access to everything but im coming unstuck with removing the door box thingamy. I have removed the two clips inside the box but it still doesent want to come out! Any suggestions?
Must i remove this box to get the fabric pannel off to susequently get to the two screws behind it?
Any help appreciated
villi
Re: Door card removal
Postby villi » Tue May 06, 2008 1:01 pm
Ok door card off.
Any suggestions on how to diagnoce a fault with the regulator?
Have checked power to the unit thats ok.
These are the connections on the regulator:-
Track Description
1 Lowering control
2 Raising control
3 Earth
4 + battery
5 Not used
6 Operation authorisation
What kind of signal should i see on track 1 and 2?
what is pin 6 all about?
Postby AlexB » Tue May 06, 2008 3:48 pm
I have no idea apart from looking in the repair manual pointed at in my message in Links section. I hope that somebody else will be more helpful...
See these files in particular:
https://meganedoksi.uw.hu/MEGANE_II/MR365MEGANE5.PDF
https://meganedoksi.uw.hu/MEGANE_II/MR364MEGANE8.PDF
terry_mccann
Postby terry_mccann » Wed May 07, 2008 9:45 am
once the box pins are out you can lift the box....try to first lift the rear side, that worked for me....
villi
Postby villi » Fri May 09, 2008 10:47 am
All sorted thanks.
Tested the passenger regulator on the drivers side and it worked fine so it must be a wiring fault/intermittence.
Any one have a wiring schematic so i can resolve this issue?
terry_mccann
Postby terry_mccann » Fri May 09, 2008 10:52 am
I only have the german version of a technical manual as PDF-file, but I don't think that might be of any use to you....
d.jessop
Postby d.jessop » Wed Jul 30, 2008 9:25 pm
Has anyone got a UK technical manual on pdf?
Also, when removing the door panel, are there any hidden clips that will always break if not removed carefully? :banghead
zdravko.barec
Postby zdravko.barec » Thu Jul 01, 2010 6:41 pm
hello everyone..
i have exactly the same problem as you have described.. can you please tell me how did you get this fixed?
Postby Anthony » Thu Jul 01, 2010 6:50 pm
zdravko.barec wrote:hello everyone..
I don't think they will reply, the last post was almost two years ago.
zdravko.barec
Postby zdravko.barec » Thu Jul 01, 2010 7:18 pm
..i am aware this is a bit of a long shot.. :-)
Postby Anthony » Thu Jul 01, 2010 10:11 pm
:lol:
tomalamix
Postby tomalamix » Fri Jul 02, 2010 9:40 am
with the schematic its possible to make some measurements and understand whats wrong with the system...did anyone got the schem?
