drivers window problem
freddy213
Postby freddy213 » Thu Feb 21, 2008 3:26 pm
how do you re set the drivers window, mine is stuck in up position. i have read about regulators on here but is there anything else i should check. thanks in advance
nickbell69
Postby nickbell69 » Thu Feb 21, 2008 6:36 pm
They can be reset by holding both front buttons in the up position for about ten seconds. I think while the ignition is off. Worth a try 1st.
[Dan]
same prob
Postby [Dan] » Sat Mar 01, 2008 9:38 pm
Done the fekn reset thingy
But no use
Back drivers window stuck doon
took inner panel aff
and cable looks tight at botom and slack at top
When trying to put window up - or down via switch
Can hear the motor trying to move - but nowt happens
PS - wheres the regulator located in the car - and any one got a link to e bay where you can buy a regulator ?
OOps its a 2004 1.5 diesel 5 door megane
TIA
[ÐÃÑ]™
- Old Bikers never die - they just get Faster -
strandman
Currently Drives:: 2004 1.5dci salon megane
Re: drivers window problem
Postby strandman » Mon Jan 11, 2010 4:06 pm
how did you get the dorr panel off, right rear!
