Noise when turning steering wheel
Ray
Postby Ray » Fri Dec 28, 2007 6:36 pm
Any ideas?
I've read about clicking noises but I get a weird noise which is best described as a creaking spring when I turn the wheel - i think in both ways not sure
Deano16v
Postby Deano16v » Fri Dec 28, 2007 7:03 pm
is the noise from inside or outside the car mate?
Ray
Postby Ray » Fri Dec 28, 2007 8:34 pm
sounds like outside/engine bay area but not sure.
Say..."Renno"
Postby Say..."Renno" » Fri Dec 28, 2007 11:48 pm
Check your p/s fluid level, while youre at it check the belt too.
The Negotiator
Postby The Negotiator » Sat Dec 29, 2007 12:49 am
Electric power steering, non?
Ray
Postby Ray » Sat Dec 29, 2007 1:25 am
oui. tis elec power steering...
IainMW
Postby IainMW » Sat Dec 29, 2007 6:18 am
Ray
I reckon your top front suspension bearings will need replacing, mine started to make a similar noise (like a twanging sound) and that's what they changed.
Are you still under warranty?
Say..."Renno"
Postby Say..."Renno" » Sat Dec 29, 2007 10:03 am
NOTE to self "Must get a workshop manual"... :?
Jonault
Postby Jonault » Sat Dec 29, 2007 7:05 pm
I had my top strut bearing replaced at my last service 3 weeks ago. I now have a twanging sound which sounds like the spring being wound up and releasing when I turn.
Ray
Postby Ray » Sat Dec 29, 2007 7:49 pm
i'm literally teetering on warranty! It's going to a non-franchise for service next saturday!
Only hear it on low speed turns (parking speeds).
nickbell69
Postby nickbell69 » Sun Dec 30, 2007 12:49 am
I have similar problem and reading various posts have heard it could be CV joints. Mine does it when turning left or right at low speeds but not when free wheeling only when in gear. Did pass its MOT like this but it's seems to be getting louder now so may have to get it looked at.
hix2003
Postby hix2003 » Mon Jan 07, 2008 9:51 pm
it's the top mounts that have gone. Apparently is is quite common. Mine went on a 2005 1.9 dci. Changed under warranty. Renault engineer knew exactly what is was when he turned the wheel and heard the twang...
cactusbob
Postby cactusbob » Mon Jan 07, 2008 10:55 pm
Yes very common on a lot of Renaults. About £65 a side for the part.
225 5dr FF + Xenons
http://www.meganesport.net
garlum
Postby garlum » Tue Jan 22, 2008 10:55 pm
Yes, this exact same thing happened to my car over Christmas. Garage fixed it under warranty. They diagnosed it very quickly and sorted it within a few hours, so it must be well known!
Users browsing this forum: No registered users and 47 guests
