o3 megane 1.6 dynamic hands free
jindgee
Postby jindgee » Sun Nov 11, 2007 8:04 pm
i recently broke down and had to be rescued by garage as i stopped and when i tried to start again the engined turned but would not fire .The car was towed in and after a short tme the engineer sead he had fixed it and it was the imobilizer had to be reset .
He fixed it from under the bonnet He only went under the bonnet and did not plug any digognostic equipment in .I asked if i could do it if it happened again but he didnt want me to know how .Does any one know how you reset it as he only took about 10 mins
jindgee
not starting
Postby jindgee » Sun Dec 09, 2007 6:59 am
Think I may have fixed it .The fault happened a few times after it was fixed by garage .It happened luckily outside my house so I disconected battery for about an hour and everything was ok for several days then it happened again out on the road .So I disconected it agin but only for about two seconds and it seems to have cured it .If you try this make sure you know the radio code how to set it as it will need to be re entered .
jindgee
not starting problem
Postby jindgee » Tue Dec 18, 2007 4:42 pm
My last message about undoing battery lead did not cure the problem permantly .It finally had to go into a independant garage who fixed the problem which was a flywheel sensor .This has now cured the problem and according to the mecanic is a common problem .I hope this helps someone else .
