HANDBRAKE NOT HOLDING ON THE RATCHET
Emma2883
Postby Emma2883 » Sun Sep 02, 2007 10:41 pm
Help i have a megane, and my handbrake will not hold on the ratchet. Is this a common problem. How do you rectify this problem.
Thank you in advance
E J COX
IainMW
Postby IainMW » Sun Sep 02, 2007 11:02 pm
It will probably need adjusting, but your handle could also be faulty? :(
As this is a safety concern get it to a garage ASAP
robznet
Currently Drives:: Megane 1.5dci
Postby robznet » Mon Sep 03, 2007 10:13 pm
Hi Emma
As Iain said - get it looked at asap, I notice you are in Wolverhampton too, Renault Wolverhampton is currently being refurbished - the place looks dead but they are still operating from portakabins at the rear!
If your car is still under warranty, pay them a visit! :D
PS - nice to know I'm not the only member in Wolverhampton!!!!
Regards
Rob
1.5DCi Dynamique with comfort pack - Antique Green.
Emma2883
Postby Emma2883 » Sat Sep 08, 2007 12:10 pm
thank you for your advice,
we have fixed it ourselves, so didnt have to spend no money. As it is out of warranty :D
E J COX
robalexclark
I've got the same problem..
Postby robalexclark » Tue Nov 06, 2007 12:59 pm
I've got the same problem and the garage says that they probably need a new "handbrake lever assembly" from Renault costing £300!! They havn't had a proper look at it but if I can fix it without requiring a new part then that would be great.
Could you please tell me how you fixed it??
robalexclark
Larry May
Postby Larry May » Wed Nov 07, 2007 5:48 pm
I need to know how to fix this, it happened the other day and the Renault garage want £117 to look at it let alone fix it.
Please help!
Megane II 1.6VVTi 5dr Expression Dec 2003
robalexclark
chuffin handbrake
Postby robalexclark » Wed Nov 07, 2007 6:52 pm
Well I've taken the plunge and ordered a Haynes manual so at least I can get the thing off and have a look at it.
Could still do with any advice that anyone has got regarding this though!
antonymorris1973
Postby antonymorris1973 » Fri Nov 09, 2007 10:23 am
Mr Girlfriends 53 Plate 1.6 vvt had the same problem ...handbrake not holding
There is a post on here on how to take the plastic section off and adjust the Handbrake itself ....
I followed this and unclipped the plastic section that surrounds the handbrake..... checked the mechanism but could not resolve ...it seemed that the actual handbrake lever was faulty and the mechanism when pulling the handle up was catching and holding .
Took into Renault Manchester .......brand new Handbrake required, this lncuded the mechanism and actual handbrake handle ....all fitted plus VAT roughly £200.
Superb Service From Renault Mcr i might add!!
Re: chuffin handbrake
Postby AlexB » Fri Nov 09, 2007 11:23 am
See my message in the Links section. Follow the link, scroll down to the last three lists of documents and open the 3rd document in the third list from the bottom. Page 37A-20.
robalexclark wrote:Well I've taken the plunge and ordered a Haynes manual so at least I can get the thing off and have a look at it.
absmegane
Postby absmegane » Fri Nov 09, 2007 11:27 am
I've had 2 handles fail on me under warranty, the funny leather
bit in the middle just went completely loose on both occasions.
Why can't Renault just go with the usual style and not try to do things
different which in the end fail, the wobbly handle is a known problem
and my dealer have changed a few others over the last few years.
- absmegane
europa
Postby europa » Fri Nov 09, 2007 11:40 am
Ours is over two years old, driven every day, no loose handbrake yet...
'05 2l Manual Pearl Black Megane LXR Dynamique 5-Door
idefix
Postby idefix » Sat Nov 17, 2007 10:23 am
I thought this had been a recall once in 2003, try confronting the garage with that.
wezhoy
Postby wezhoy » Sun Nov 18, 2007 12:02 am
i had this problem as well
a quick fix is to
remove the plastic trims
you will see the teeth
theres a little arm looks like part of a coat hanger
bend it a little bit with a pair of pliers (small twisting motion)
this will give the affect of tigtening the adjustment !
thats how i fixed it and i have had no problems since
1.6VVT Ottoman Dynamique 03' Plate with Comfort Pack & Sat Nav
"Take It Easy!"
Larry May
Postby Larry May » Mon Nov 19, 2007 12:54 pm
Got mine fixed but needed a new handbrake assembly at £185!
Told them to leave the old one in the boot, got it home took some of it to bits and guess what was wrong.
A tiny bit of plastic that the button release spring needs to bend against has broken off so the spring does not force the button back out thus allowing the ratchet to engage. A tiny little bit of plastic making the handbrake work, that cannot be right can it.
I am going to try and speak to Renault about it.
