Will Not Start - Engine Turning Over OK - 1.9DCI
Liggy
Currently Drives:: Black 2004 Renault Megane CC Privilege
Re: Will Not Start - Engine Turning Over OK - 1.9DCI
Postby Liggy » Wed Jul 10, 2013 9:23 pm
I'm hoping maybe you guys can help me as well. I'm having a similar problem after my car ran out of fuel. I've found the priming pump and I was trying to squeeze it earlier, but it didn't seem to be doing anything. How long will I need to do this for? Should the priming bulb feel fully inflated or feel deflated?
2004 Renault Megane CC Privilege 1.9DCI.
freelanderuk
Postby freelanderuk » Thu Jul 11, 2013 9:07 am
Pump it till it feels firm then pump a bit more , you will see the fuel in the clear pipe
Drive it like you stole it
My flickr
Liggy
Postby Liggy » Thu Jul 11, 2013 10:25 am
Thanks. Does anything need done to the priming pump before I start squeezing it? Or can I just access it and begin as is?
Postby AlexB » Sat Jul 13, 2013 6:09 pm
"as is", as you wrote... There are two valves in the priming bulb. Help them work by squeezing and releasing it quickly. You will also need to have diesel in the tank...
burtsmit
Currently Drives:: 2006 Megane 11 1.9dci Sedan
2006 Citroen 2.0VTS Coupe
Postby burtsmit » Mon Sep 17, 2018 2:26 pm
Very Helpful
my car does the same, Yet how do you detect these micro leaks? when I pump my primer the air wont budge.
