Electric window mk 2 Megane 2006 1.4 petrol
Mikkee1
Postby Mikkee1 » Thu Jun 01, 2017 8:52 pm
Hi i am looking some advice on my car electric window has stopped working it's not regulator as when I tested window relay and took cover of manually activated it the window then was able to move up and down freely. Which would rule out the most common faults. I have looked everywhere for some info to help resolve the problem but cannot find any thing so any help would be much appreciated.. also driver wi Dow is not working but I have the feeling that may be because the motor has went
grandadbobby
Re: Electric window mk 2 Megane 2006 1.4 petrol
Postby grandadbobby » Thu Jun 01, 2017 9:06 pm
the electric windows can drive you nuts.
lt's not uncommon to take the door card off, wiggle the wires and it works, then when put back together doesn't work.
Had it myself. Usually a temic connector off ebay will fix it, unless ofcourse the motor has gone.
Personally, l fixed mine last week by taking my original temics apart and cleaned the contacts thoroughly with wet and dry paper.
Good luck
Bob.
noelo
Postby noelo » Fri Jun 02, 2017 9:47 am
if you are handy with a soldering iron,put a layer of solder on all the pins on the window regulator (both sides)
this will give a good connection when plugged back in as the pins are now slightly fatter allowing the connections
on the socket to bite into the solder.
it solved my window problem
best of luck
snapdragon
Postby snapdragon » Sat Jun 03, 2017 3:14 pm
I agree, terrible quality of connector (the female part) and shutting the door is enough to stop it working again.
Tinning all the pins with a thin layer of solder is a great idea.
Bigjohno1986
Currently Drives:: Renault Megane estate
Postby Bigjohno1986 » Sat Jun 03, 2017 4:49 pm
Hi does anybody know how to fix my windows please. The only window that works is rear drivers side window. Checked all fuses under dash and their fine. There's no power going to windows. Is there any fuses under the bonnet???? Many thanks ash
grandadbobby
Postby grandadbobby » Sat Jun 03, 2017 8:56 pm
Hi Bigjohno,
it's never that easy mate, it's checking switches, door cards off ( not a 5 min job) and fixing the temic connectors to the motors. That is if the motors are ok.
Plenty on the net to guide you.
Good luck
Bob.
snapdragon
Postby snapdragon » Mon Jun 05, 2017 3:32 pm
Tinned my front passenger pins - very easy, solder flows well - so far so good.
Rear passenger, all burned up.
Useless.
https://mega.nz/#!F4QH1JJI!1wve2H8Qa5fw ... 1IMw9QWd6Q
https://mega.nz/#!EpRkkQbB!ac9PjeT_FcfR ... gXFVudN_X4
Users browsing this forum: Bing [Bot] and 26 guests
