central locking
robbie1003
central locking
Postby robbie1003 » Sun Dec 11, 2016 9:49 pm
my cc has developed a strange fault, when the boots open the central locking flicks open and shut and boot light flashes. any clue to the cure? doesnt do it all the time but obviously it need sorting. any help appreciated.
robbie1003
Re: central locking
Postby robbie1003 » Wed Dec 14, 2016 11:03 am
took out the switch that's inside the diamond badge, thankfully it's quite serviceable, cleaned the contacts and wd40 just to remove any moisture. Worked fine thismorning, time will tell if the switch was the fault.
q292u
Global moderator
Currently Drives:: 2003 Clio. The Megane died.
2001 Audi A2 1.4 SE
Re: central locking
Postby q292u » Wed Dec 14, 2016 12:12 pm
Bloody water getting in again?
Seems to be a common theme..
Does it not rain in France?
robbie1003
Re: central locking
Postby robbie1003 » Wed Dec 14, 2016 3:55 pm
My jag has its moments with its tailgate, Jetwash is usually the culprit rather than rain. The megane did leak on the joints of the rubber seals but a good clean and degrease has cured that problem. Use to happen on sunroofs a lot back in day, bit of muck between rubber and the glass, same.on the seal of the switches.
Users browsing this forum: No registered users and 51 guests
