Help , 2008 megane dci (Battery?)
Lclarke99
Currently Drives:: 2008 Megane estate 1.5dci
Postby Lclarke99 » Sun Nov 27, 2016 9:33 pm
Hi I've recently ended up with a 2008 Megane est dci which I plan on keeping as my daily runner
Which battery do you suggest to use as the ones I keep using end up draining very quickly yet my alternator must be fine as car runs without a battery
Also upon trying different battery's sometimes it would tell me my battery was low when I know they were fully charged new ones , also before it said low battery it would usually come up with select neutral first which it was
q292u
Global moderator
Currently Drives:: 2003 Clio. The Megane died.
2001 Audi A2 1.4 SE
Re: Help , 2008 megane dci
Postby q292u » Sun Nov 27, 2016 10:13 pm
See this thread: viewtopic.php?f=2&t=26192
noelo
Postby noelo » Sun Nov 27, 2016 10:46 pm
Sounds like a faulty alternator - You should have greater than 13.5v dc being generated with engine running.
Running alternator without battery connected may cause damage.
q292u
Global moderator
2001 Audi A2 1.4 SE
Re: Help , 2008 megane dci (Battery?)
Postby q292u » Tue Nov 29, 2016 12:02 pm
I think you have a dodgy alternator.
If it fails to charge more than one battery, it's more likely to be the alternator.
I'd reckon charging the battery requires more juice than running the engine (once started) so it sounds like it's not up to the job.
Should be easy enough to check - try measuring the voltage from the alternator with the engine running..
Sounds expensive. Sorry.
Lclarke99
Postby Lclarke99 » Sat Dec 03, 2016 7:33 pm
Checked the battery and volts today. It's not the battery after all . The car still flashes up select neutral and low battery sometimes tho , will refuse to start now and again. Any1 else experienced this
M3gan3dci
Currently Drives:: 2007 Megane 1.5 dci 86
Postby M3gan3dci » Sat Dec 03, 2016 9:14 pm
Have you had the cca checked on the battery?
Users browsing this forum: Bing [Bot] and 35 guests
