Removing fuel gauge?
sprintster
Currently Drives:: Megane II Dynamique 1.4 VVT 2004
Postby sprintster » Mon Oct 24, 2016 6:04 pm
I've decided to try and sell my Megane for spares or repair because of electrical faults.It's got a full tank of petrol in it though.I thought I might be able to get at the tank through the fuel gauge(or is it the pump) under the back seat.Does the black ring around it just unscrew?
q292u
Global moderator
Currently Drives:: 2003 Clio. The Megane died.
2001 Audi A2 1.4 SE
Re: Removing fuel gauge?
Postby q292u » Tue Oct 25, 2016 11:53 am
If it's anything like my old Micra, the fuel sender/pipes/float thingy unscrews if you tap it with a hammer and screwdriver. Carefully. Anti-clockwise.
There's probably a proper tool for this, which we can't buy.
sprintster
Postby sprintster » Tue Oct 25, 2016 1:22 pm
That's what I thought.Was wondering if a bit of GENTLE heat from a hot airgun might help free it.Obviously not a blow torch though! Lol.
q292u
Global moderator
2001 Audi A2 1.4 SE
Postby q292u » Tue Oct 25, 2016 1:30 pm
:shock: Heat. Fuel Tank.. :oops:
sprintster
Postby sprintster » Tue Oct 25, 2016 2:16 pm
The way I see it,it won't be any worse than my motorbike fuel tank sitting above a hot engine.If I'm still around I'll let you know if I was wrong! :shock: :-)
sprintster
Postby sprintster » Tue Oct 25, 2016 5:04 pm
So I took the safer option and poured a kettle of boiling water around the ring.I don't know if it made any difference as it still took quite a hammering to get it to turn but I'm in now and the tank is full to the brim. :-)
q292u
Global moderator
2001 Audi A2 1.4 SE
Postby q292u » Tue Oct 25, 2016 6:10 pm
Result! Brute Force and Ignorance wins again!
Users browsing this forum: Google Adsense [Bot] and 32 guests
