Took the wheel arch liner etc out as I new I couldn't fit new connectors through that pathetic sized hole. But, the connector block had snapped completly and the bulb had shattered at the rear. Not to worry, I was cutting the ends of the wires anyway and had bought a box of 10 H7s some time back.
Just had enough wire to strip back and crimp on 2 new spades then build up the connector, new bub in and the jobs a goodun', I should cocoa.
No light and no voltage at the connector. Now given the damage it's fair to asume that the spades had touched and shorted out the electrics, so where's the fuse?, where's the fusebox come to that? After failing on info from the owners manual and haynes ever faithfull google came to the asistance.
For christs sake, even knowing what I was looking for it took me 1 1/2 hours this morning to reach the fuse
![banghead :banghead](./images/smilies/icon2_banghead.gif)
Basically remove battery, I didn't thing the tray needed to come out
Remove screws from disguised fuse box near battery then break it open, I say that as it sealed by a small section of plastic that has to be cut or snapped.
Try to remove multiples unit, cant so battery tray has to come out. Remove numerous clip that don't come out so snap off.
Prise full wiring harnes out of the way to remove tray.
No, on the 1.5dci the ECU is mounted on the battery tray, no mention of this in any info I'd found.
Remove ECU, rease massive wiring harness clips and bend all the wiring out of the way after reasing several more clips
Remove multiplex unit, not as easy as the "slide out .... unit" info I'd got, there are massive retaining barbed clips to the rear, took a big screwdriver to release it.
Now I can see all the large blade fuses that simply aren't visible without all that work. But they were all rated from 40 to 70 amps so I had my doubts and indeed they were all good.
Now what I hadn't realised is that the multiplex unit is mounnted in a sort of half sheath, it's held in again by barbe clips that take a fine screwdriver and 2 pairs of hands to release
Ureka turn over the MPU and underneath, bloody underneath there's about 20 various mini blad fuses and 1 10amp one had blown.
Don't ask me if all is well as I was so pissed of at that point that I gave it up for the day, but why oh why is it designed to be that way? It's not inconceivable that a headlap fuse will blow is it.
![screw loose :nut](./images/smilies/nutter.gif)
![off topic :ot](./images/smilies/offtopic.gif)
![hmmmm :hm](./images/smilies/icon2_hm.gif)
