Alarm Problem
Skeggyboy
Alarm Problem
Postby Skeggyboy » Mon Apr 11, 2016 3:22 pm
Hi my Alarm will go off its self after locking it after a few moments alarm will sound
i have to press the on button 6 times to get it to stay off
any suggestions what might be wrong?
thanks
Re: Alarm Problem
Postby Stranger » Mon Apr 11, 2016 3:35 pm
Check for any obstructions, I once had a similar issue and it was something that was stuck in the tailgate lock area.
Skeggyboy
Re: Alarm Problem
Postby Skeggyboy » Mon Apr 11, 2016 3:54 pm
Hi Thanks i have checked all doors and bonnet incase there was something wrong so fa i can not see anything wrong
i might have to disconnect the alarm at this rate
Re: Alarm Problem
Postby Stranger » Mon Apr 11, 2016 6:29 pm
Ok here's a few things that have caused this in the past:
Spiders or other insect
Open window, even just a crack
Door, boot, bonnet not properly closed or not closing fully
MeganeMule
Re: Alarm Problem
Postby MeganeMule » Mon Apr 11, 2016 8:17 pm
My Laguna mkiii had an issue with the bonnet catch so I disconnected as I didn't think anyone would break into the bonnet !! On my Mrs old A3 they were prone to the battery's in the horn unit leaking and then it would go off as and when it wanted. Not sure if the Megane is the same set up.
Skeggyboy
Re: Alarm Problem
Postby Skeggyboy » Mon Apr 11, 2016 8:39 pm
It does have a bonnet switch it arms fine the alarm goes off 1 minute after arming
Twix
Currently Drives:: Megane
Re: Alarm Problem
Postby Twix » Wed Apr 13, 2016 8:01 pm
Have you tried disarming the motion sensors to see if that helps?
Skeggyboy
Re: Alarm Problem
Postby Skeggyboy » Wed Apr 13, 2016 8:04 pm
Hi yes thats how ive been arming the alarm i bought 2 new sensors from ebay soldered them on still going off ggggrrr
Twix
Re: Alarm Problem
Postby Twix » Wed Apr 13, 2016 8:06 pm
Instructions here viewtopic.php?f=2&t=4817
For mine it is stop the engine, remove the card, listen for the click, replace the card, press the stop start button lots of times in a row (not too fast) until the indicators flash then get out of the car and lock, the bleeps will be different.
Twix
Re: Alarm Problem
Postby Twix » Wed Apr 13, 2016 8:07 pm
Sorry don't know then.
Users browsing this forum: No registered users and 65 guests
