Led bulbs
Tayle
Currently Drives:: Megane cc mk2 2007
Led bulbs
Postby Tayle » Fri Jan 29, 2016 4:26 pm
:banghead Hi has anyone changed the rear stop/break light bulb to led on a megane convertible I've changed all the other bulbs but this one won't come on lights up when I pull it out a bit but then it's not locked into place tried two different makes on ebay and no luck
Phil and Liz
Re: Led bulbs
Postby Phil and Liz » Fri Jan 29, 2016 7:27 pm
does the normal bulb still work ?, if so is the measurement from locating pins to base where terminals are the same ? if you put the led bulb in the bulbholder can you get access to press the terminals in the bulbholder ? if so does the bulb light up ?
Phil and Liz Jackson
Lanark
Tayle
Re: Led bulbs
Postby Tayle » Fri Jan 29, 2016 9:28 pm
Thanks for the quick reply yes the standard bulb works as I took it out to try the led bulbs they are the same fitment but only light up when placed in and not pushed into place for some reason
llywnog
Re: Led bulbs
Postby llywnog » Sat Jan 30, 2016 12:22 pm
check if the bulb has offset pins.they only fit one way
Tayle
Re: Led bulbs
Postby Tayle » Sat Jan 30, 2016 3:59 pm
Hi Yes
Yes they are offset and they fit but don't light up when pushed into place
Tayle
Re: Led bulbs
Postby Tayle » Mon Feb 01, 2016 7:09 pm
Has anyone had any luck with finding some led indicator light bulbs that actually work without excessive flashing
Also stop/tail light leds that work in a convertible mk 2 thanks as the two I purchased wouldn't light up when fitted
Thank you
Users browsing this forum: No registered users and 46 guests
