Injector location urgent
Oli3108
Currently Drives:: Megane privilege
Postby Oli3108 » Wed Oct 28, 2015 11:24 am
My car won't start and I'm desperate now
Car was fine for about 100 miles then struggled to get it started
Got it going drove 5mins parked up cam back 5 mins later won't start
Got it towed home and low and be hold it fired up
Drove about 40 miles with stops and all fine got home parked in drive for about 2hours and now won't start
When it do fire I could smell fuel but ran fine
So wanting to look at cleaning all the injection and the fuse box as I have seen on YouTube
I believe it's an electrical fault
The car ticks over but won't fire up
Please help I'm desperate now I've got someone coming to do a reading on the ecu 2night
freelanderuk
Re: Injector location urgent
Postby freelanderuk » Wed Oct 28, 2015 2:01 pm
reading the codes is the first step to sorting the fault , post your codes and you will get some help
Drive it like you stole it
My flickr
Oli3108
Postby Oli3108 » Wed Oct 28, 2015 10:21 pm
So the lad turned up plugged it in and guess what no codes.....
So he advised I clean all the injectors so I've dun that while I was doing it thought I may as well check/clean the fuse box
Still won't start
Postby AlexB » Thu Oct 29, 2015 9:20 am
On OBD one needs to look at the fuel trim values and sensor readings, not just codes...
When you wrote about 100 miles, did you mean that you just bought it?
Oli3108
Postby Oli3108 » Thu Oct 29, 2015 10:07 am
No I had been out and aboutin it
Oli3108
Postby Oli3108 » Fri Oct 30, 2015 8:18 am
Bump
Users browsing this forum: No registered users and 73 guests
