Megane 1.5 dci air bubbles in fuel line
cankwas
Postby cankwas » Tue Jan 20, 2015 10:36 am
Hi all, I have a 05 1.5 dci which is having starting problems. I changed the glow plugs because they appeared to be dead. Starting issues still persist after new plugs. Cranking over in morning it starts then injector fault lights up. Looking in engine bay to the left clear pipes (fuel?) appear to have bubbles running through them. Could this be the cause? Any ideas on where to check for air ingress?
Thanks.
tomalamix
Re: Megane 1.5 dci air bubbles in fuel line
Postby tomalamix » Tue Jan 20, 2015 7:48 pm
ai bubbles on the return line is normal, bubbles on suction pipe isnt. please take a picture or describe better which pipe is with fully filled with fuel and which one is with bubbles, post back then.
Colster
Currently Drives:: Megane 2 Phase 2 2 2006 1.9 dCI
Postby Colster » Thu Apr 23, 2015 1:31 pm
seems to be common on all diesel Meganes. Mines a 2006 1.9Dci 130. Same problem, and similar symptoms to yours. I'm about to change my holed pipe, so will update soon.
Colster
Postby Colster » Fri Apr 24, 2015 10:10 am
Changed my pipe this morning. The old pipe was chafed underneath, so couldn't be seen from above, but quite obvious when removed from the vehicle. Problem solved.
Users browsing this forum: No registered users and 50 guests
