driver's window
dimitrius
Currently Drives:: renault megane II 2005
driver's window
Postby dimitrius » Thu Nov 06, 2014 8:30 am
Hello, my driver's window, left hand side one, stopped working. I know thiw topic has been covered a lot. Can you please five me a hint on how to remove the door card and what to look for? thanks.
dimitrius
Re: driver's window
Postby dimitrius » Fri Nov 07, 2014 9:04 am
in case something is wrong with the switch can i use the co drivers switch instead?
Are these parts interchangeable?
Re: driver's window
Postby AlexB » Fri Nov 07, 2014 5:51 pm
The card removal guide is in the manual in the sticky thread with manuals, above this thread. File MR365MEGANE5.pdf
It is the window regulator - a small black box attached to the motor. Sometimes cleaning its connectors may work, but usually the controller needs to be replaced. You can find a replacement on ebay at about £20-25.
dimitrius
Re: driver's window
Postby dimitrius » Fri Nov 07, 2014 10:08 pm
thank you very much Alex, I shall try it and post the results.
noelo
Re: driver's window
Postby noelo » Sat Nov 08, 2014 8:42 pm
if you are handy with a soldering iron,put a layer of solder on all the pins on the window regulator (both sides)
this will give a good connection when plugged back in as the pins are now slightly fatter allowing the connections
on the socket to bite into the solder.
it solved my window problem
best of luck
johnny1916
Re: driver's window
Postby johnny1916 » Thu Nov 13, 2014 5:15 pm
Hi, I was hoping I could get some help here, . I have a 2008 renault megane eco 2, the one with 6 gears. My window on the front passenger side stopped working months ago. Mechanic messed around with it and got it working again but said the motor and regulator might need replacing. Anyway it stopped again. So a friend said if I get the part he would put it in. I went to an auto parts store and they asked if it was 2 pin or 8, I have no idea and need to know before I order it. I would strip the door and have a look but I don't have tools and my friend lives a good bit away. So my question is could anyway know the pin I need. The dealership wont or cant tell me what I need.
Phil and Liz
Re: driver's window
Postby Phil and Liz » Sat Nov 15, 2014 8:17 pm
my 08 has had a new harness on each side and still sometimes stops working, i then remove the door card spray the connections with wd40 and make sure there is a good connection. get your friend to remove the door card and play about with the connections. If it does need a motor or regulator the door card could stay off while you get one, awkward but possible
Phil and Liz Jackson
Lanark
