Use the dielectric grease when installing the coils. If they have silicone rubber boots, then use the fluorine grease, otherwise a cheap high-voltage silicone grease will do. See my post in Parts section.
Was one plug of a different colour?
simba7 wrote:Hi Alex,
There is 1 o2 sensor which alternates fast. Is this the one I should be looking at?
I can try taking a laptop after work and checking the o2 sensor after the journey today.
Also i have ordered 4 Valeo Ignition Coils to see if this fixes the issue.
In my mind i believe it to be the VVT again. But im no expert.
