Intermittent engine starting problem
Jocheung
Currently Drives:: Renault Megane 1.5 DCi 80 2004
Postby Jocheung » Tue Sep 24, 2013 2:41 pm
I've just purchased a 2004 Renault Megane 1.5 DCi 80. It has 118K miles on clock, part service history and 8 previous owners.
After a few days of owning car I had problems starting the engine. Symptoms as follows;
1. Unlock doors via remote fob.
2. Open door and dash board does not light up. Normally lights up with 'PLEASE INSERT CARD' but this message is not there when there's a problem.
3. I then insert key card into slot.
4. Press 'START' button and no response, no dash lights, just silence
After several attempts of locking/unlocking door and spraying WD40 onto electrics in bonnet the 'PLEASE INSERT CARD' message displays and the engine starts as normal. It will start as normal throughout the day. So far the problem has only occurred in the mornings
The left wheel arch bulb access cover and a bulb cover were missing but I managed to source these from eBay.
I really like this car and would like to get this problem fixed. This maybe difficult which would explain why there are so many owners for this car.
Does anyone have any suggestions please?
460316DSG1
Currently Drives:: RENAULT MEGANE CC REG 2007 MK 2 1.9 DCI
Re: Intermittent engine starting problem
Postby 460316DSG1 » Tue Sep 24, 2013 4:06 pm
Hi. It has to be Damp or Dry Joints on connectors if it works after spaying with WD40.
Take connectors apart and spay inside, it will be trial and error, one of them is not making a good connection.
Switches as well give them a spay.
get some Damp Start and spay all the Cables you can get at.
Hope that helps.
460316DSG1
tomalamix
Postby tomalamix » Tue Sep 24, 2013 8:18 pm
the cover were missing...what about water inside, did you check it?
Jocheung
Postby Jocheung » Tue Sep 24, 2013 8:49 pm
The weather seems dry tomorrow so will try disconnecting some plugs and spray some cleaning oil on the contacts. I have nothing to lose. There was no water to be seen in the fuse box compartment. I had driven in the rain a few times without any problems. Its just starting it up in the mornings that's the problem. Once it starts up its fine for the rest of the day.
Postby AlexB » Wed Sep 25, 2013 12:00 pm
Perhaps, due to the hatch cover missing earlier and water damage, the UPC refuses to power up the other ECUs intermittently...
Jocheung
Postby Jocheung » Wed Sep 25, 2013 12:35 pm
I gave the electrics a good spray behind the battery and around the fuse box compartment. Tried to start up car but still had the same symptoms. Did a few random things in the car and the dash lights lit up when I closed the glove box. Looked at the fuses in the glove box and located one for the dash. The fault symptoms I get are exactly the same as when the dash board fuse is taken out. Next time this happens I will fiddle with this fuse. Hopefully that is the cause.
Jocheung
Postby Jocheung » Sat Oct 05, 2013 11:07 am
I think the problem has been fixed.
After experiencing the problem a few times I finally traced the fault area to either the UCH board or the wiring loom surrounding it (area above glove compartment). The wiring seemed fine and the only thing I could think of was to replace the UCH board. I've heard these things could cost around £600 from Renault to be fixed so I was looking for a cheaper solution. I managed to find a seller from a popular auction website who could supply a used UCH for £85. This price including reprogramming the used one with the same details from the old one. I had to post my one to seller for it to be cloned. After 2 days of sending off I received both units. The new UCH has been fitted and used for 4 days and so far I have not experienced any of the old problems. :)
460316DSG1
Postby 460316DSG1 » Mon Oct 07, 2013 7:47 am
How easily was it to get the UCH Board out/in.
460316DSG1
Jocheung
Postby Jocheung » Thu Oct 10, 2013 2:23 pm
It was fairly easy.
Remove the door frame plastic cover near door hinge.
Remove the side dash cover.
Use T20 screwdriver to remove 5 screws which secures the glove compartment.
Remove glove compartment by pulling it out.
UCH is located just above glove compartment and secured by a bolt. Unscrew this then unplug the plugs and thats it.
Takes me about 5 minutes.
Update: Since replacing the UCH I've had no problems so I'm convinced its now fixed.
freelanderuk
Postby freelanderuk » Thu Oct 10, 2013 2:51 pm
Thanks for the update
Drive it like you stole it
My flickr
460316DSG1
Postby 460316DSG1 » Fri Oct 11, 2013 7:30 am
Thanks for the information.
460316DSG1
