Megane offside front brake hose
br1xton
Currently Drives:: 1.5 dci
Postby br1xton » Fri Feb 22, 2013 3:22 pm
Is it easy to change the offside front brake hose urself or shud I take it to a garage to be done
Re: Megane offside front brake hose
Postby AlexB » Fri Feb 22, 2013 11:57 pm
Very easy, just read the manual first. Clean everything first. Then undo the compression joint where the hose meets the rigid pipe. Prepare some sort of a cap to plug the pipe. Then do the other end. On assembly undo the bleed screw on the calliper, remove the cap and quickly assemble the compression joint. Some brake fluid will escape, but not much. DO NOT USE CLAMPS - they damage the hose. Then bleed all wheels, use 1L of fluid, either DOT4 or, better, DOT5.1. Half a litre will be fine, if the fluid was recently changed.
Any rust from the rigid brake lines need to be removed and the pipework painted over with hammered Hammerite.
The manual is here
https://ray-lee.co.uk/megane/dialogys/MR364MEGANE3.pdf
Users browsing this forum: No registered users and 78 guests
