Windscreen washers
Windscreen washers
I have a 2004 Renault Megane. My front screen washer stopped working the other day. When i have checked to bottle is full and when i work the windscreen washer i get water coming out of the rear screen jet. The rear screen jet also works when i use stalk for the rear
- Bumpy macaroon
read these posts below, possible goosed pump or blockage, apperntly its a pain to get to the motor.............good luck
https://www.meganeownersclub.co.uk/forum ... =rear+wash
https://www.meganeownersclub.co.uk/forum ... een+washer
https://www.meganeownersclub.co.uk/forum ... light=jets
Bumpy and full of coconuts.
Re: Windscreen washers
Hi. i unfortunately have the same problem as above with my scenic 1.6 2004. ITS NOT THE PUMP!!! I had these checked by mechanic twice. His saying thats computer fault... Ouch! at least 300 quid. Im browsing everywhere for last month searching for another ideas...ANYTHING COMES AROUND?
- Currently Drives:: megane hardtop coupe convertible 55 plate 1.6 vvt dynamique
Hi i have 1.6 cc 55plate, mine do the same every so often, lift your bonnet and make sure the wire isnt trapped!
Ta Keely
Ta Keely
I haven't checked the links in the previous posts, but on some models the motor is bi-directional - ie it will spin one way for the rear and the other way for the front. Access on mine is by removing the bumper - lots of plastic clips at the top and three 10mm socket bolts at the bottom + Torx 20 in the wheel arches.
As has been mentioned - check the wiring. Try operating the controls for the washer whilst measuring the polarity and voltage on the motor. This might give some clue.
- Currently Drives:: 2003 MEGANE PRIVILEGE 1.9 DCI
I have a 52 plate 5 door, neither my front or rear washer jets work at all.
it makes the noise as if its trying to work but nothing comes out, i have tried
unblocking the pipes.... no luck
tracing the pipes to check for holes.... no luck
its not loosing any fluids but i just cant seem to get anything out?
can anyone help me?
much appreciated
Matt
can anyone help me?
much appreciated
Matt
My 2 penny advice would be to remove the bumper / expose the motor and disconnect most of the tubing and see what happens. It should pish fluid one way or the other...
Let us know how you get on.
- ikhan
We had a problem on my brother's old 307 whereby the motor sounded like it was working perfect, but did not deliver any water to the jets. For the price of a pump, I would change that first before spending on the UPC etc....
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
Lowered 45mm (Spax)
Thanks davelowe
i will have a look when i get home tonight and will let you know how i get on.
regards
matt
regards
matt
Further to my post yesterday, i got home last night and had a fiddle with my wipers,
here is how i managed to get the problem sorted,
1st of all i took the whole front bumper off (you dont need to but its easier to see everything once its off)
at the bottom of the washer bottle there is a black and white block that the piper for he jets attach to.
i took the whole block off (before water will come out of bottle once this unit is off!)
this unit splits into 2 peices, inside of this there is a small grey cylinder,
this cylinder was covered in junk (can only imagine the washer bottle has run dry and suck soem crud into this)
once this was all cleaned up, i put it all back together and both front and back are working great!
hope this is of help to someone as i took me ages to try and figure out what seems to be a very simple problem!!
Matt.
Matt.
Excellent fix!
- Currently Drives:: Renault Megane II Sport Tourer 1.5dci 100
Hi
how do you do this without removing the bumper?
You have to remove it. It is easier than you may think.
damian1981 wrote:Hi
i usually access it removing the undertray cover...the pump comes out just pulling it out
- Currently Drives:: 2004 megane
I have a 2004 Renault Megane my front washer pump sprays out water no problem but the rear on the other hand does not spray water I can hear the pump work but nothing anybody got any idea much appreciated guys n girls
Users browsing this forum: No registered users and 67 guests
