how do the bottom lights on the door work?
mattymoore93
Postby mattymoore93 » Wed Jul 25, 2012 3:38 pm
as above really i am new to owning a megane and cant seem to get them to turn on
777HAM
Currently Drives:: 2002 Megane 1.6 Dynamique.
Re: how do the bottom lights on the door work?
Postby 777HAM » Wed Jul 25, 2012 8:37 pm
When I brought my 2002 Megane a few months ago I noticed that none of the door lights worked either. I removed one and found that the connector was not joined and it looked brand new and never been connected as there was no sign of wear on either the metal points or the bulbs! I then checked the other 3 and they were all the same so I connected them and they now work for the first time. My car must of come off the production line on a Friday afternoon!
mattymoore93
Postby mattymoore93 » Sat Jul 28, 2012 11:14 am
Well checked to see if tgere plugged in and they are.
Cant believe all owners on this forum dont help newbies with a simple question
morganjake1544
Postby morganjake1544 » Sat Jul 28, 2012 6:09 pm
The courtesy lights in the bottom of my doors only light when,
1. I open the door to get in, then they dim and go out after 30 seconds or when I start the engine.
2. I turn the engine off, then they dim and go out after 30 seconds or when I open the door.
They don't come on when I open the underfloor storage (on some versions/specs they do) and there is no actual switch to turn them on.
Do yours ever come on, or not appear to work at all?
Which spec of Megane do you have? Extreme, Authentique, Expression, Dynamique, Privilege, Oasis, Maxim?
Do any other electrical items/accessories not work either, if so they may share a blown fuse?
Hope that helps some.
mattymoore93
Postby mattymoore93 » Sun Jul 29, 2012 11:48 am
i haave a Dynamique version the lights dont come on at all. but they are all plugged in and bulbs inplace. they dont come on at all. thanks.
Postby davelowe » Sun Jul 29, 2012 10:05 pm
You checked the fuses I hope...
On the dynamique, the floor cupboards do have switches. It is not uncommon for the switches to either not work, or the flaps to not close. The UCH works this out after a while and does not activate the door lights.
Check the fuses, the bulbs, the switches, then disconnect the -VE battery terminal for 20 minutes. Report back!
mattymoore93
Postby mattymoore93 » Mon Jul 30, 2012 7:44 pm
ive checked some fuses but unsure which one is for the floor lights. the flaps dont seem to have any switches on them. ive disconnected the negative of the battery but that hasnt semed to do anything.
Postby davelowe » Mon Jul 30, 2012 10:07 pm
Open the flap and tug the floor pocket out (just plastic lugs). There should be a connector where it closes. If there isn't, this is not the area to look at.
mattymoore93
Postby mattymoore93 » Tue Jul 31, 2012 2:10 pm
done what you said and there isnt anything there. where is the fuse for these lights. just to make sure ive checked the correct one.
morganjake1544
Postby morganjake1544 » Tue Jul 31, 2012 3:52 pm
Follow the link and fuses are detailed in Section 81C.
http://ray-lee.co.uk/megane/dialogys/MR364MEGANE8.pdf
No such thing - it's a Megane. :D
MartyW
Currently Drives:: Renault Megane CC 1.6 VVT in Ottoman Blue
Postby MartyW » Wed Aug 01, 2012 12:32 pm
mattymoore93 wrote:Cant believe all owners on this forum dont help newbies with a simple question
Give people a chance to answer mate, not everyone is on there computers all day, and there is nothing simple about Renaults people have tried there best to solve your problem.
Postby davelowe » Wed Aug 01, 2012 10:21 pm
I would just like to point out that this thread will not be allowed to descend into an argument!
The OP has not written back either - but I get both points.
Lets wait and see - chill out guys! 8)
mattymoore93
Postby mattymoore93 » Thu Aug 02, 2012 10:34 pm
Tried everything that has been suggested
Think am just going to go down easy route and say they dont work lpl
Users browsing this forum: Google [Bot] and 24 guests
