Stuck Ignition Coil
MEG04
Currently Drives:: RENAULT MEGANE 04
Stuck Ignition Coil
Postby MEG04 » Fri Feb 24, 2012 10:36 pm
Hi guys, I have been trying to get the pencil coil changed on my Megane 04 1.4. Its a petrol engine but it sounds like a tractor :)
I managed to replace the first one easily by removing the the bolt and replacing it with a new one, but the last coil on the 4th cylinder is stuck.
Any ideas how i could get it off?
Scenic
Currently Drives:: Scenic 111 1.9dci 2010
Re: Stuck Ignition Coil
Postby Scenic » Sat Feb 25, 2012 1:33 pm
Do you mean that the actual coil is stuck to the spark plug or that the 10mm bolt wont move? if stuck to the spark plug try twisting with a pair of pliers or small molegrips as the coil wont be of any use afterwards but be careful of not snapping the spark plug and if the bolt use a ring spanner and gently tap it so it moves.
MEG04
Postby MEG04 » Sat Feb 25, 2012 4:53 pm
Thanks for your reply, the coil is stuck to the sparkplug., i will give another shot this week and report back.., hope it works :)
MEG04
Postby MEG04 » Fri Mar 02, 2012 5:30 pm
Thanks alot!!!, managed to get it out with some pliers today :cool: what a difference!!!
Scenic
Postby Scenic » Fri Mar 02, 2012 7:08 pm
Glad it worked for you :-)
