STEERING LOCKED / NOT LOCKED
Meggy-megane
Currently Drives:: Renault Megane 1.6 16v
Postby Meggy-megane » Wed Oct 26, 2011 10:22 am
My 2003, 1.6 16v have been parked since 23 September 2011 due to the need to replace a dephaser pulley and cambelt hence it was showing "CHECK INJECTION" on display. When I parked the car the ignition was turning but would not start the car, however when the mechanic arrived over the weekend to change the the cambelt and pulley the words "STEERING LOCKED / STEERING NOT LOCKED when I insert and pull the card and the car would not start. I have browsed most of the answers on the forum but non of them are giving me the exact cause and what I am expected to do in order to unlock the streering, and what is it causing the car not to start. The car is standing at a very awkward position, in order for the mechanic to be able to change the pulley we need to push the car but the steering is locked.
Please help :life :life God Bless
tomalamix
Re: STEERING LOCKED / NOT LOCKED
Postby tomalamix » Wed Oct 26, 2011 5:03 pm
do you ear a "Click" sound like something is disengaging when you press the Start button? normally you must ear it otherwise the locking mechanism isnt working and requires further investigation.
Meggy-megane
Postby Meggy-megane » Fri Oct 28, 2011 7:12 am
There is no click sound, dashboard lights and even the radio is working.
"Randy, Ray, Paddy :banghead could you guys please HELP :!:
tomalamix
Postby tomalamix » Fri Oct 28, 2011 10:25 am
no click means the steering lock mechanism isnt working. worth a check, its under the steering column. you have to take the cover beneath and you will see it, its attached with only 1 screw. see if the plug is correctly attached. the screw is left, not as the usual screws that are right.
good luck
Meggy-megane
Postby Meggy-megane » Fri Oct 28, 2011 10:51 am
Thanks, I will try that one. Have a good day
rory1983
Postby rory1983 » Mon Nov 07, 2011 6:47 pm
its happened to me today, the car has only been fixed 6 days. any more help out there?
tomalamix
Postby tomalamix » Mon Nov 07, 2011 11:40 pm
did you checked the locking mechanism as stated on the thread?
arran.vigar
Currently Drives:: Megane II 03
Postby arran.vigar » Tue Nov 15, 2011 8:45 pm
Hi i have a similar issue accept mine is unlocked and will not lock whenever i start the car it just makes a cluncking sound then airbag light and service light come on. When i turn the car off there is a click and the steering wheel has a little judder but the lock does not engage. any ideas tomalix you seem to be good at this stuff
tomalamix
Postby tomalamix » Tue Nov 15, 2011 9:07 pm
swap the mechanism, it really seems to be that mechanism your problem. doesnt need to be coded.
good luck
Postby davelowe » Tue Nov 15, 2011 10:27 pm
Be aware that (if I remember correctly) the mounting bolt is a shear-head type and a left hand thread. Meaning you turn it clockwise to undo it.
arran.vigar
Postby arran.vigar » Sun Jan 08, 2012 11:19 pm
tomalamix wrote:swap the mechanism, it really seems to be that mechanism your problem. doesnt need to be coded.
good luck
When you say the "mechanism" do you meant to open the unit up and change. or the steering lock as a whole. I though they were coded?
tomalamix
Postby tomalamix » Mon Jan 09, 2012 10:30 am
their aren't coded, no worry about that.
the mechanism is separated from the the lock actuator. The black box must be coded, but the mechanism is separated from the black box and dont need to be coded. Take it out like previously stated.
arran.vigar
Postby arran.vigar » Tue Jan 10, 2012 10:24 pm
brilliant thanks very much pal will give that ago when i get some time especially now i found out my mot is due in may (just after the entry of steering locks and air bag lights as RfRs grrrr)
Take Care
Arran
Users browsing this forum: Bing [Bot], Google [Bot] and 46 guests
