panoramic sunroof dynamique 2ltr
the sunroof clicks but does not open . i have manually opened the roof , when i turn the switch on the roof closes with the motor but does not open again it just clicks , anyone got any ideas many thanks roy .
Re: panoramic sunroof dynamique 2ltr
I have the self same problem with the clicking but not opening sunroof,pain in the arse. Whereabouts would i find the sunroof motor? many thanks....
the motor is at the rear of the back part of the second sunroof panel in the centre. you can pull down the roof lining (only velcro pads ) you will see the small hole for 4mm allen key to be able to move the sunroof good luck
- Stranger
- Site Admin
- Currently Drives:: BMW X1
Is it a click, click, click, click continually for a few seconds or is it just one click?
If it's the former it could be that it, or the motor, might be out of alignment.
With the dial is set to the close position, when i press the button i hear four rapid clicks. If i set the dial to any other position and press the button i hear nothing.
I just completely opened my sun roof using an allen key but it would not shut by pressing the button, so i had to close it using the allen key again. ( what a complete git that was). Please help me any one please
it clicks once for each switch position .if i hold the centre button it clicks for a few seconds , many thanks
i have tried another switch still the same. any ideas thanks roy
today it started working and then stopped again help
Users browsing this forum: No registered users and 41 guests
