Electric Window Problem
I've just joined the Owners Club and having difficulty connecting to the right areas regarding a query I have over my Megane.
I have a 52 plated 1.6 3 door which has developed a problem with the electric windows sometimes coming down as they should with a touch of the button and on the otherhand having to repeatingly press the button to lower the windows an inch by inch process.
This sometimes occurs when I want the windows to come down and up.
I'm assuming its relay problem but if any of your members could help me solve this very annoying problem I would be much appreciative.
Best regards
Gareth
Best regards
Gareth
- m.bedforth
- Currently Drives:: Megane Sport Tourer Oasis Dynamique Manual Petrol '05
Hi and welcome. Your post should really be on the Ownership Problems section which is on the index on the homepage, use 'New Topic' and someone is bound to come along to help. There are lots of window problems I'm afraid. You could try Search in the meantime by using the search button on the home page. I can remember finding it all a bit confusing when I was new to the site but I am sure you will find your way around very quickly. ATB.
PS I copied your message on to the Ownership Problems page so hopefully you should get a response soon. The site is very slow tonight to get on to and to get around. 9.45pm Sunday
- m.bedforth
Ray excuse my ignorance and assuming that the f in fup is decent, which one of these does 'fup' stand for, if any?
Acronym Definition
FUP Facility Utilization Plan
FUP Fair Use Policy
FUP File Utility Program
FUP Firmware Update
FUP First Usage Phase
FUP Fixed Unit Price
FUP Follow-Up
FUP Forming-Up Point
FUP Free Use Permit
FUP Frequently Used Program
FUP Full Up Power Pack
FUP Funktionsplan (German: Logic Diagram)
Acronym Definition
FUP Fair Use Policy
FUP Firmware Update
FUP Follow-Up
FUP Free Use Permit
Re:
Ray wrote:Moved.
My internet is capped at 128Kb cuz I broke the FUP so everything is slow for me!
Have you tried to reset the windows?
With the windows up, you hold the rear switches up for about 10 seconds.
im having the same problem with a megane i am test driving tomorow the pasenger window does it only. its a 3 door though so how would i go about reseting the windows?
cheers
Re: Electric Window Problem
Once the windows are fully up, hold the switch in the up position for a good few seconds. As stated in a previous response, 10 seconds seems reasonable. I had to do this recently after a flat battery and it didn't work first time on every window. For some I could do it from the individual switches but the final one would only let me do it from the main switch panel in the driver's door. However they all reset in the end.
this sounds about right. before i arived the guy had said the battery had run flat so he had been running the engine. cheers guys! il nock the guy down a few pennys first like but then il try fix it doing the above after a deal is made
Naughty! Yeah, tell him you heard that the window regulators might need replacing and hope that there is no unfortunate twist . . and they do!
work wonders guys thank you! put the deposit down tonight and i pic the car up friday
- Currently Drives:: Renault Megane 100 1.5DCi
Reset works great... bit confusing why it does it though
Renault Megane II 54 Plater 1.5dCi 100
- Currently Drives:: renault megane 2003 1.6 16v vvt
thanks guys had the same problem after unplugging battery yesterday... after reading this post tried that and all working fine now.. what a daft setup!!! but then again thats renault for you!!!
