Keyless Entry Problem
Hi all,
Ive only owned by Megane 1.9 DCi for a few days and over all I love it, especialy the keyless entry system.
The only issue I have is that I can only unlock the drivers door or boot. The passenger door will not open, the sensor behind the handle doesnt seem to detect anything. I also cant use the botton on the handle to lock the door.
Both the drivers and boot locks work fine as well as the auto window / dead lock feature.
Ive tried both cards and its the same with each of them. Can anyone confirm that either the sensor is duff or that I should only be able to open the drivers door via the keyless system.
Stuart
Stuart
No this a common fault in the keyless entry system and I had it on Megane too. Heres the bad news. Most garages charge around £108 for the handle and £108 for the sensor. So if your car is out of warranty I would just live with it unless they can do you an amazing deal. You may find they start working in the wet, mine usually did.
Tell me about it... I bought a Clio 1.5 DCi from them about 3 years ago on a 51 plate when they were still called Reg Vardy.
Within 5 mins of leaving the dealership the dash lit up like a Christmas tree. It took 3 return visits for them to fix it. They said the diesel pump had gone and was full of metal filings. After a replacment pump, injectors, ecu and fuel lines it turned out to be a £4 seal allowing unmetered air into the engine.
But it was all paid for under my warranty
Stuart
Stuart
Hi, i had the same problem with my drivers door sensor not picking up, phone renault and they told me it was the pickup sensor around £40, i thought id see if i could repair it as am tight and dont like wasting money, anyways try this as it may save you lots of £s
Remove Door card and let it hang down towards the floor no need to remove completely
Where handle is there will be a plastic cover held on with two clips remove this, dont worrie if you break it and its not important
Next use a screw driver to lock the door catch in door and lock door using key card or button on handle
Now look into where the handle is and there will be some plugs remove the one at the bottom of the handle, wait about 10 secs and put plug back in, this should reset the sensor and should now start working.
If your button does not work its normally due to being stuck, get a small plastic fork, or screw driver and prise button out gentle, just enough so button moves, squirt up with WD40 and keep pressing and prising out untill it become unstuck, now your handle button works and you aint spent a penny
- BurntCarcus
- Currently Drives:: Grand Scenic 2008 1.9Dci (130)
How do you find out if your car has this feature? I have a card but has never opened the door unless i hit the button on the card (ive had it about 8 mths). I have wee plastic covers under my handle but im not sure if they are just there by default or it has this feature. Dosent say in my handbook if i have it, just esplains how it works.
Back from Zafira hell....... Good to be home. Number 3 scenic bought and "im lovin it"
- nickbell69
- Currently Drives:: GT 150
- Location: Hardings Renault, Hemel Hempstead 01442 292506
KEYLESS HAVE I GOT IT ????
IF YOU HAVE KEYLESS ON YOUR MEGANE, BUTTONS WILL BE ON ALL DOOR HANDLES BEST WAY TO KNOW, IF YOU HAVE GOT IT OR NOT
JASON.......
JASON.......
Megane II GT 150 "07"
- BurntCarcus
Thanks for all your replies.. I contacted the dealership I bought it from and according to them the passenger side will not open using the keyless system. Now I find this difficult to believe as Ive had the car for about a week and its a bit of a pain not being able to open the passenger side door with the keyless system. Also he fact that Renault went through the trouble of fitting the keyless door handles as well as sensors to both doors.
The button on the handle seems fine and 'clicks' when I press it just like the working drivers side. The button on the boot also works fine.
I think I might have alook at removing the door card and try resetting the sensor.
Stuart
Stuart
- nickbell69
