Problematic megane team f1
Posted: Sun May 21, 2017 10:16 am
Hi all. I require some advice. If recently purchased a f1 megane and it's the biggest mistake to date.previous owner patched it up just to get rid of it..to cut a long story short it needs a rebuild from what I suspect. Iv done a compression test and I'm getting 120 psi across all cylinders. The car seems to crank a little longer to start once warmed up. It smokes badly when driving under boost, deceleration and clears up after a while of idling. Iv installed a brand new agents turbo previously suspecting that it was. I can't seem to find decent technical data online and the Renault agent here don't want to share technical information regarding this vehicle. Iv barely done 1000km and this car has coated me a fortune already. Does anyone perhaps know if my compression is too low before I decide to remove this engine? Help is greatly appreciated
Thanks .
Malcolm
Thanks .
Malcolm
