Hello people new member
Posted: Sun Nov 27, 2016 6:33 pm
by 19541947
Hi people got a problem ,hope you can help,2005 megan 2.0turbo ,done oil/filter change now smoke everywhere,running rough when hot /warm ,as anyone had same problems cannot believe doing a oil change can cause these problems,if you can help would be great
Re: Hello people new member
Posted: Sun Nov 27, 2016 9:42 pm
by Stranger
Hello there, are you sure you haven't put too much oil in?
Re: very very smokey 2.0 turbo
Posted: Wed Nov 30, 2016 8:11 am
by q292u
Where exactly is the smoke coming from?
If you have spilled oil on something that gets hot, you will get smoke until it you clean it off or it burns off.
Just a thought, but you did use the correct oil?
Re: very very smokey 2.0 turbo (after oil change)
Posted: Sat Dec 03, 2016 12:06 am
by AlexB
You didn't overfill, did you?..
Posted: Tue Dec 06, 2016 10:09 am
by 19541947
Thank s for reply,Will check again what you have said,What is the spec of oil to use ,normally use 5/30,many thanks
Posted: Wed Dec 07, 2016 10:37 pm
by AlexB
Millers 5w40 nanodrive CFS nt. The guys from Millers say it is suitable for road, just don't attempt long service intervals (longer than a year). It's ester based, cleans the engine, the nanotechnology reduces friction/wear/temperatures.
For women choose Millers 5w30 EE nano - long life, suitable for slow/short runs.
The OEM oils are listed in the Parts forum.
