I have checked the bulbs and fuses all of which are fine. Side lights and full beam are also ok. Anyone had the same problem and can offer me a solution
Dipped headlights have stopped working
Re: Dipped headlights have stopped working
Which fuses did you check? The one you need to verify is a 10 fuse next to the battery. If that is still in tact, you might have to check all the wiring. Not usual that both will fail on you at once.
