Help - Crazy Disco Lights when braking / indicating
Discussions around the Mégane 225.
boryc
Currently Drives:: Megane 225 Cup
Postby boryc » Mon Jul 18, 2011 9:59 pm
Hi All,
Need some help or advice if anyone can assist. Ive got a Megane Sport 2006.
I've got a problem with my lights when im braking or indicating. If I turn right my indicator will work then go quicker and back to normal ticking speed if thats the best way to describe it and repeat that process.
Also Ive been told when i brake my indicator/hazard lights will flash at the same time and when i indicate my brake lights will come on at the same time so Im confused at what this could be and where to start looking, there are many things I suppose I could check but if I knew what I was looking for it might help :-)
Thanks in advance :-)
chewbacker
Currently Drives:: megane 19 dci
Re: Help - Crazy Disco Lights when braking / indicating
Postby chewbacker » Sun Jul 31, 2011 6:13 pm
remove rear lamps and check for water in the connector and bulb holder, best bet is a bad earth. use a voltmeter to check you have no grounded lives. the whole rear light only uses one earth once you have found which wire that is check that you don't get a circuit between the other wires and earth. you must do this with the light plug removed and the bulbs will give a false reading. good luck
Return to “Megane 225”
