225 airbox removal
Discussions around the Mégane 225.
pru
Currently Drives:: 2005 renault megane 225 trophy&98 alfa romeo 3.0 gtv
225 airbox removal
Postby pru » Wed Jul 21, 2010 3:37 am
hi everyone,uk newbie here,i need to remove my airbox on my 225 trophy so that i can make enough room to see the bulkhead at side of the servo so that i can feed some new wires through for a laser jammer ive bought,ive removed the panel filter but does anyone know how many bolts hold the airbox in&what type they are ie. torx/hex nuts,i can feel a bolt under the front left side of the box,do i need to remove the battery aswell,i need to do all work from inside engine bay as i cant get under the car to remove protective floor pan,thanks for any help,pru :conf
Re: 225 airbox removal
Postby Anthony » Wed Jul 21, 2010 8:40 am
Hi pal
To remove the airbox the battery, battery tray, airbox hose feed and ecu have to be removed. I would recommend that you get a trim removal tool for this job as the clips that hold the loom to the battery tray are a real pain.
From there the airbox just pulls forward and up off of its rubber mounts.
pru
Postby pru » Wed Jul 21, 2010 11:27 pm
Anthony wrote:Hi pal
thanks for reply anthony,ive learnt something else cos i thought ecu was in passenger footwell,i dont suppose you no off an easier route to bring some wires through bulkhead other than the way im going,removing glovebox-airbox-then drilling a hole side off servo,thanks pru
Return to “Megane 225”
