Water inside door on Megane 225
Posted: Wed May 12, 2010 12:53 pm
Hi all,
Is it normal for a little water to appear to be leaking out under the door between the plastic panel door card and the metal of the door? Its not leaking into the car and the carpets are not wet. It doesn't seem to breach the rubber door seal but its definately getting water inside the door.
Is this the same for everyone else or should the inside of the door be water tight?
