Hi all,
Is it normal for a little water to appear to be leaking out under the door between the plastic panel door card and the metal of the door? Its not leaking into the car and the carpets are not wet. It doesn't seem to breach the rubber door seal but its definately getting water inside the door.
Is this the same for everyone else or should the inside of the door be water tight?
Water inside door on Megane 225
Re: Water inside door on Megane 225
I had that on my 1.6vvt but never on my 225.It's a common fault, but not that I am aware of on the 225.
A computer once beat me at chess, but it was no match for me at kick boxing.
The problem effects both cars unfortunately, just have a read on Meganesport. It does seem to be rarer but thats probably down to far fewer examples.
