Hi New to the Megane world, I pick up my 225 on Wed.
Have already ordered Eibach springs and would just like to know more info on the dump valve available and is it an atmospheric one or reculating one I go for. I presume forge valves are the best ones to go for.
Appreciate any advise give.
Jason
Megane 225 Dump Valve Info
Re: Megane 225 Dump Valve Info
I got mine from Forge think it was around £116 mark but dont quote me on it.Easy to fit But if your fitting the blanking plate just to make you aware it took me 3 HOURS......just to put in one screw the other 2 went in fine.The blow off valve and hose was on within 5 minutes.So enjoy your whoooooshing along the road.
A computer once beat me at chess, but it was no match for me at kick boxing.
- Matty_225
- Currently Drives:: Megane 225 LUX
what is the blanking plate for
Hi, the blanking plate is to cover where the original Diaphram Recirc valve went.
Because in a sense, you are relocating the 'dump valve'.
- Matty_225
so if its a standard recirc valve there must be a vaccum pipe?
If you blanking the recirc off do you also have to blank the vac pipe off?
Vac pipe goes into Dump Valve.
Guys what's a good dump valve kit to go for cheers
Forge is the one I have and no complaints from me
Forge or HKS.
This guy has not fitted a blanking plate is this good or bad as it looks a total pain to fit
www.meganesport.net/dumpvalveguide.htm
Ps. any tips on how to get the old one off is it a 10mm socket.
while fitting a dump valve, there is a valve that came off while i was removing the old intake pipe please see pic. It is the hose on the left hand side with the sleeving has pop out and the plastic hook's have broken what is it called so that i can order a new one pleases guys. it seems easy enough to fit a new part I am just not sure what it is.
vondug
Top
vondug
Top
