power maxX, Diesel system cleaner
Used a good or bad product with your car? Share your experience here...
Postby joeishmather » Thu Apr 15, 2010 3:46 pm
anyone ever used this stuff?
power maxX high performance diesel system cleaner, diesel systemreiniger.
i was sold it today by nationwide autocentres, they said there apparently the only place that do it,
on the can it says its a treatment that should be done every 6 months.
cheers
Re: power maxX, Diesel system cleaner
Postby joeishmather » Thu Apr 15, 2010 3:47 pm
just checked ebay its £8 lol :-(
Postby joeishmather » Thu Apr 15, 2010 4:00 pm
direstraits
Laguna III Ph2 Exception
Postby direstraits » Thu Apr 15, 2010 4:58 pm
Renault forbids any fuel additives. Simple as that. :)
Postby joeishmather » Thu Apr 15, 2010 5:30 pm
direstraits wrote:Renault forbids any fuel additives. Simple as that. :)
how would they know ive used one??
direstraits
Postby direstraits » Thu Apr 15, 2010 6:15 pm
You would. :) Stick to the good quality oil (fully synthetic 0w40 f.ex.), OEM oil and fuel filter and change them regularly. Thrashing a car from time to time will help cleaning the injection and exhaust system. High pressure pumps (diesel) are sensitive to additives, small pieces of teflon coating inside the pump can errode and get to the injectors damaging them permanently.
Postby joeishmather » Thu Apr 15, 2010 7:04 pm
direstraits wrote:You would. :) Stick to the good quality oil (fully synthetic 0w40 f.ex.), OEM oil and fuel filter and change them regularly. Thrashing a car from time to time will help cleaning the injection and exhaust system. High pressure pumps (diesel) are sensitive to additives, small pieces of teflon coating inside the pump can errode and get to the injectors damaging them permanently.
you say you would, so does that also mean they would? :( lol
Sadret89
Currently Drives:: RENAULT MEGANE 1.5dci 80, INDUCTION KIT, 8K XENON HEADLIGHTS, 225 SPORT FULL BODY-KIT & EXHAUST SYSTEM, SOUND SYSTEM, TDI TUNING BOX, EDC BLACK STUFF FRONT BRAKE PADS
Postby Sadret89 » Tue May 18, 2010 1:04 pm
Use Comma's Diesel Detox, has won awards by Autocar mag for the past 4 years, I used it and it absolutely was brilliant
DocWS1
Currently Drives:: Megane 1.9 TDi
Postby DocWS1 » Wed Sep 09, 2015 7:27 pm
I used Wynns triple action Gold for my 1.9 diesel. Worked great and got rid of the check injection light. I stick to high quality diesel now as the cheaper stuff wrecks the engines.
Return to “Product Tests”
